10-09-2010, 08:00 PM | #1 |
Rep 5,482
Dirty car reveals aero secrets, holes in hood not just there to lure c*cks to the M3!
I was getting ready to clean my car when I thought, hmm, that's weird, lots of dirt collected on top of the hood bulge. Then I looked closer and noticed that there were little trails where condensation from being parked outside all night at work had run across the car on the way home. Some of them led to the engine air intake on the hood. But wait, the "dead" hole on the other side has no trails leading to it. Could it be? Does the hood intake actually get a little positive pressure (or maybe just suction from the engine) at speed? Could the ///M in ///M3 still mean something? It appears so. Kinda neat to see this thing actually works. Also, it looks like there might be a cat hanging around my parking lot at work, awesome.
10-09-2010, 08:09 PM | #2 |
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
Wait.....what? You do know that, what would be the driver side foglight, is a big air ram right?
10-09-2010, 08:37 PM | #3 |
Non-Guido Jersey Resident
35
Rep 676
I feel like those trails are coming FROM the hole, not TO it. The front air inlet is going to pass a lot of air through which is why water always sprays from there after washing the car.
10-09-2010, 09:49 PM | #4 | |
Rep 5,482
The only thing that explains it is a pressure differential caused by the intake. I guess somebody (besides BMW) needs to get this thing in a tunnel with a smoke wand next to the intake and see what happens. The front intake has to make a 90 degree turn before it gets to the airbox. Which might explain why the high pressure zone where the hood meets the windshield was worth exploiting.
10-10-2010, 09:18 PM | #5 |
Rep 8,496
Yeah, right side is intake, left side is a vent
look on the underside, they're also pointed different directions. looks like it gets air circulation under the hood and the right side goes straight into the airbox or not? Last edited by mdosu; 10-10-2010 at 09:29 PM.. |
10-10-2010, 10:55 PM | #7 |
35
Rep 676
10-10-2010, 11:32 PM | #8 |
Rep 111
Extended summer driving on I-90 yielded a bug collection on the inside of the driver's side vent. I don't see how that could be unless air goes out of the hole, so it's not an intake.
10-11-2010, 12:00 AM | #10 |
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
I think at lower rpm highway type driving air passes through the airbox and the excess goes out the hood vent but at higher rpm and full throttle operation the engine needs more air and actually draws air in though the hood vent.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
10-11-2010, 12:07 AM | #11 |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
There is no air flow through the passenger side. Slits in the underside rubber let water drain out. That's it. It's purely cosmetic. The driver's side is mostly to let air flow through the air box so it doesn't get hot when the throttle is closed. If it wasn't there, while you were braking or otherwise not on the throttle, the air going into the intake at the lower left side and the grill intake would be dead-headed and the air in the air box would get heat soaked form the engine compartment heat. With the hood vent, there is constant flow through the box to keep it cool so when you do get back on the throttle, it's not hot air. As noted by someone already, bugs and debri sometimes collect on the inside of this vent indicating flow is mostly going out. When raining, or after washing, at highway speeds water comes out of it. It does not flow into it. From a standing start, it probably sucks air into it at full throttle, but I don't think that is it's main purpose. It's main purpose is to allow flow through to keep the air in the air box from getting hot.
10-11-2010, 03:01 AM | #12 | |
Rep 2,426
“For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.”
- John 3:16 |
10-11-2010, 05:21 AM | #13 |
Rep 1,792
The hood vent still sucks in air from the outside, check out the picture. S65 comes with a cold air intake from the factory (#3). That's why the stock intake is so efficient that an aft. market intake kit usually does not yield enough gains to justify the price tag.
The dead-air theory above is not correct since even when you're on the brakes with the throttle closed....the engine is still ingesting air (or the motor would bog and bog then shuts off). So the air in the airbox is never constant once the motor is running. The picture also highlights probably the weakest link of the intake...which is the air filter itself. Then it is not a surprise that we've been seeing most gains when we replace the factory unit with BMC, K&N, MS...etc..etc.. http://www.e90post.com/forums/showpo...66&postcount=1 |
10-11-2010, 08:02 AM | #14 | |
Rep 3,303
Additionally, it has been well documented but I'm too lazy to find the threads that discuss this that in fact the driver's side air vent is in fact VERY active and serves the purpose of getting air into that engine at higher rpms when she gets really thirsty for air (see, and you just thought she sucked gas). I can't remember where and I have searched but somewhere its listed the ridiculous amount of air it sucks in at 8400 rpms. Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
10-11-2010, 02:42 PM | #15 | |
Rep 5,482
To put that in perspective in 'murrican units, that's over 70 gallons per second, or enough to suck all the air out of your typical 2000 square foot house in about half an hour. There may have been little bit of extralegal high rpm activity on the drive that generated these photos.
10-11-2010, 03:32 PM | #16 |
1M advocate
214
Rep 878
If the intake is for "sucking in" air then why did they choose to put it in a notorious low pressure zone?
2012 BMW S1000RR
2011 BMW M3 |
10-11-2010, 03:51 PM | #17 |
Rep 3,076
Drives: 2023 iX M60 Oxide
Someone put a piece of paper on it and then rev the engine, see if it blows away or sticks to the hood at various rpm.
10-11-2010, 03:57 PM | #19 | |
Rep 263
I need to find a datalogger, but the MAF reading can be measured directly. |
10-11-2010, 04:04 PM | #20 | |
Rep 5,482
10-11-2010, 04:06 PM | #21 |
1M advocate
214
Rep 878
Yes but the intake isn't located in the cowl. It's about 3/4 up the hood.
I should've said near ambient, not low pressure. (granted this isn't a model of an m3 but it's close enough for general observation.)
2012 BMW S1000RR
2011 BMW M3 |
10-11-2010, 04:11 PM | #22 |
Rep 2,991
