10-19-2010, 04:17 AM | #1 |
Let's Race
16
Rep 125
Dinan Suspension with Spacers
I'm trying to find out if somebody have some pictures of the Dinan suspension with 15/12 spacers on 19" Stock wheels? I'm fairly certain that this is the setup I'm going with once I get back.
Is this a good combo or should I stay away from the spacers? I was trying to search for some pictures but I only have access to a computer with <56k for 30 min a day here in Afghanistan. It will take me roughly 30 to 40min to view the famous spacer reference thread from EAS due to all the pictures. Any assistance would be appreciated. :-)
2010 BMW M3 Coupe Alpine White - DCT |
10-19-2010, 06:37 AM | #2 |
One mod leads to another ...
419
Rep 2,900
Here you go. The only difference is I was running 12mm spacers all around.
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
10-20-2010, 01:00 AM | #3 |
Let's Race
16
Rep 125
Thank you so much for the pictures. You M3 looks great. How would you rate the setup compared to stock?
Thanks... :-)
10-20-2010, 01:32 AM | #4 |
Rep 1,676
i don't have the spacers but the dinan stage 1 susp with camber plates and it is alot better then stock you will love it. can't speak on the spacers though. i got wider Volk's so i am running 265/285 so felt no need to get spacers
Street- 08 E92 M3- Sparkling Graphite/ Fox Red/6sp
Track- 10 CRF 250-PR2 Race Motor/Ohlins TTX Susp Hauler- 06 Ford Skyjacker F250 4WD |
10-20-2010, 07:13 AM | #5 |
Rep 153
I'm on Dinan stage 3 with F15/R12mm spacers. Ride is slightly better with none of that stock squishiness. Responsiveness has sharpened considerably. Excellent kit !!
01-13-2011, 09:35 AM | #7 |
419
Rep 2,900
Nope
01-13-2011, 11:56 AM | #8 |
Rep 6,125
Dinan's own wheels for E9X M3 actually comes with spacers.
So, it can't be bad.
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
01-30-2011, 08:31 PM | #9 |
Rep 920
i'm running dinan stage 1 with gts 359 wheels and 12mmf/10mmr and it works good. I could probably go 15f/12r
09 E92 M3,AW/FR. MODS:Performane Kidney Grills,Side Gills,Exhaust Tips,BMW Performance Pedals,359 Satin Black GTS Wheels,275/35/19R & 255/35/19F PSS's,Dinan Stage I Suspension,Macht Schnell Spacers 12mmF,5mmR,Rear Fogs,Euphoria 6k,LCI Tails,LUX v3,OEM IND Painted Alpine White CF Performance Spoiler, Front Splitters, and Front Reflectors,Gloss Black Hood Vents,M Performance Steering Wheel.
01-30-2011, 09:50 PM | #10 |
Rep 561
01-30-2011, 09:55 PM | #11 |
Rep 3,274
in those pics the drop does look favored considerably to the rear, but I almost dont mind that. its good for ground clearance
I plan on running Dinan Stage 1 suspension with 12mm spacers all around, 19" 220M wheels.
02-10-2011, 12:15 AM | #12 |
Rep 1,676
the camber plates push the front up just slightly. in person you can't tell as much. that pic looks higher than it really is. i think it is less than a 1/4 of an inch higher
02-12-2011, 12:06 AM | #13 |
E60_to_E90
36
Rep 1,201
Is there a consensus on MS vs RS Technik vs TMS spacers? Seems like most are opting for MS, but the RS Technik sure look nice too.
I too am contemplating Dinan stage 1 with 12mm spacers all around -- to accommodate my winter setup witho having to swap spacers each time I swap wheels. Or else I'd go 15 up front.
2011.5 E90 Dinan M3, SS II, M-DCT, EDC, M Drive. 20" MORR VS8.2 wheels
Performance Mods: Dinan St.1 suspension, exhaust, intake; TTPs; BPM St.II, DCT, servo tunes Cosmetic Mods: OEM CF splitters, mirrors, center console, spoiler; Arkym CF diffuser; LUX; tint |
02-15-2011, 05:28 PM | #14 |
Rep 6,696
Drives: F30 340i
anyone have pics of stage 3 on their car? i think stage one looks too similar to stock or at least in pics...
02-15-2011, 05:32 PM | #15 |
Rep 3,274
no difference between stage 1 and stage 3 in terms of the drop, stage 3 adds sway bars and things like that.
02-15-2011, 06:06 PM | #16 |
Rep 6,696
Drives: F30 340i
02-15-2011, 06:15 PM | #17 |
E60_to_E90
36
Rep 1,201
Isn't stage 3 actually less of a drop than stage 1, due to the camber plates? IIRC, Dinan indicates a 1/4" drop up front with stage 3 vs. the 1/2" drop with stage 1.
02-15-2011, 06:30 PM | #18 |
Rep 6,696
Drives: F30 340i
