11-26-2010, 04:06 AM | #1 |
Rep 3,161
BBK from 335i
Will my stoptech BBK from my 335 work on a M3?
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
11-26-2010, 08:15 AM | #2 |
Rep 751
Stoptech or Dave Zechhausen could tell you for sure. I think, if the bias division is the same it should work. If not, they would have to install different size pistons, and you might need different mounting brackets. Since the M3 can accommodate the larger rotors, you would give up a bit of cooling capacity and, I think, clamping leverage, but that's getting beyond my level of understanding.
11-26-2010, 09:38 AM | #3 |
chris
278
Rep 12,144
i believe all you need would be different mounting brackets.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
11-27-2010, 12:45 AM | #5 |
chris
278
Rep 12,144
bigger master cylinder? i dont think u need this. if you buy an m3 specific kit, u can use the oem master cylinder. if op is trying to retrofit a bbk from a 335 onto an m3, u wont need a bigger master cylinder either.
11-27-2010, 06:01 AM | #6 |
Rep 751
12-02-2010, 01:09 PM | #7 |
Supreme Allied Commander
3886
Rep 54,519
Drives: F80 M3
There are a few things that need to be taken into account.
You will need new mounting brackets. You'll have to see if the piston sizes are the same. You'll need to see if the rotors/hats will work on the m3 hub and if they will not obstruct proper mounting of the caliper. Lastly, you'll need to confirm that the master cylinder is indeed the same size and provides the same amount of pressure as the 335. This could great a very hard or soft pedal depending on the variance. |
12-02-2010, 01:13 PM | #8 | |
Rep 3,161
