12-05-2010, 10:36 PM | #1 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
>> HP Autowerks << Get Your TC Kline Parts Here!
Single Adjustable Coilovers
This is the coilover kit to take your car to the next level. TC Kline offers a kit specifically made for your BMW. Extensive R&D has been done on and off the track to provide an unparalleled level of quality in every kit they sell. With this kit, you can adjust rebound externally front and rear plus have the added benefits of ride height adjustability (up to two inches). The True Match System includes proprietary valved KONI single rebound adjustable shocks and our super trick VVS alloy springs. Unlike other coilover systems, our rebound adjusters and wide range of spring rates enable a true match to your driving needs and preferences. Encompassing both street comfort and track performance, this kit is unsurpassed in its class. The TCKR True Match Kit includes Front Struts, Rear Shocks, Springs, in your choice of available rates. TCKR Rear Height Adjustors and specially formulated Buna rubber rear mounts. Rear mounts may be upgraded to TCKR monoball rear mounts. (Monoball mounts offer better shock control at the expense of some street comfort.) Camber plates are REQUIRED with the E9X M3 kit due to the fact that the factory strut mounts are too tall for the coilovers to thread properly. Proper sleeves are included to run these coilovers. http://www.hpashop.com/product.sc?pr...&categoryId=-1 Double Adjusable Coilovers Proven on the street and track, this system is unmatched by any other system on the market. TC Kline's unique Smart Shock technology mated with our VVS alloy springs (see springs) make this ride height adjustable kit the most versatile available. Incorporating separate external compression and rebound adjusters, the shocks can be dialed from street comfort to a full race setup in minutes. These features combined with our complete selection of VVS alloy spring rates make this kit the uncompromising choice for both street comfort and track performance. The Smart Design System is perfect for driving school enthusiasts, autocrossers, club racers, and serious pro racers alike. We can also build Double Adjustable Struts and Shocks for use with stock diameter springs for competition classes which require stock configuration. Kit includes TCKR Height Adjustment and Buna rubber rear mounts and Proprietary KONI Double Adjustable Shocks. Camber plates are REQUIRED with the E9X M3 kit due to the fact that the factory strut mounts are too tall for the coilovers to thread properly. Proper sleeves are included to run these coilovers. Choose the Swift spings option with thrust bearings to make this kit even better! http://www.hpashop.com/product.sc?pr...&categoryId=-1 The difference between single adjustable and double adjustable besides the obvious of one more adjustment, is that while single adjustables only allow you to change the rebound setting, double adjustable allow changes to both rebound and compression. The single adjustable shocks are very comfortable on the street but the double adjustable actually ride better due the fact that they can be more specifically set up. This is a great way to increase the performance of your m3 while dialing in an optimized right height. This kit uses linear springs unlike KW and Bilstein, which results in more predictable handling and less body roll. Last edited by HP Autosport; 10-17-2013 at 03:55 PM.. |
01-23-2012, 11:42 PM | #2 |
3847
Rep 54,376
Drives: F80 M3
TCK Double Adjustable coilovers
Better than KW Clubsports, custom spring rates available and motorsport valving package in all DA struts and dampers.
In stock and ready to ship! |
11-28-2016, 12:38 PM | #9 |
3847
Rep 54,376
Drives: F80 M3
Cyber Monday Free shipping in US48. Shipping charges will be refunded after confirmation of your order
