12-20-2010, 01:49 AM | #1 |
Wellee
14
Rep 64
500 miles in my new M3
Hi everyone, I've had the car for a week and I'm loving it! Just curious what you guys think is the maximum amount of time I should allow the car to idle for. I've done it a few times, sitting there for 5-10 minutes each time while fiddling with the iDrive. I just read that it's bad to let it idle for an extended period during break-in. Any thoughts?
12-20-2010, 02:03 AM | #2 |
Rep 1,769
Drives: 2011 E92 M3 ZCP
Whaaaaa????
Enjoy your car, it can idle for hours. Read the manual, it's a great read and will teach you everything you need to know about the greatness you bought.
'12 CLS550 Palladium Silver - loaded
'11 E92 M3 ZCP - SG/B-EXT/CF, M-DCT, loaded '11 E93 328i, BSM over Saddle Brown, sport, loaded '08 550i M-Sport, Carbon Black (Gone but not forgotten), '06 W211 E55 AMG (Gone, miss this animal),'01 E39 540i Sport |
12-20-2010, 02:42 AM | #3 |
Rep 13,043
Drives: BMW M340I G20
Get in it a drive, don't idle an engine too long.
12-20-2010, 03:44 AM | #4 |
Rep 85
12-20-2010, 05:29 AM | #5 |
Rep 348
I let the car idle until this really loud noise in the engine quiet down. Usually takes about 30-60seconds. Is the noise normal? I would assume it's a cold start right? And it's better to let the car idle until the cold start noise goes away right??
12-20-2010, 10:02 AM | #7 |
Rep 4,167
Start 1 min wait if 50 degrees, 2 if cold. Drive and go, drive it to warm it up personally, just dont get on it until its good and warm. THEN SEAL THAT ENGINE properly!!!
Audi R8 v10 Ford Raptor m3e46freak@yahoo.comfor all euro parts!! ebay/craigslist verified/ m3post/e46fanantics/m3forum/zpost/bimmerforum |
12-20-2010, 12:15 PM | #8 |
Rep 8,496
in this case, you might as well not start the car and just run the idrive on battery, easier and cheaper to replace than anything that's going on in your head that might break from excess idling.
The battery is heavy duty, there's features where you can keep your headlights on for like 1.5 mins after you shut off your car, I doubt running the idrive for 5 mins drains more battery than that. |
12-20-2010, 12:23 PM | #10 |
octane chick
81
Rep 1,187
Drives: ex-M
12-20-2010, 12:59 PM | #11 |
Member BMW CCA Los Angeles
32
Rep 470
Drives: 2022 M8 GC Comp
+1 The manual specifically states to begin driving right away in a reasonable manner until the engine reaches normal op temp. Reason for this is the get everything warm and lubed asap (same reason people used to idle the car until the temp increased). But bmw seems to recommend that it's better to get engine to full op temp asap by driving it. With all this said, I think it's ok to let it idle from a cold start every once in a while and from an already warm start all the time.
Current Rides:
2022 ///M8 GC Comp Much enjoyed: 2018 ///M4 ZCP || 2014 ///M5 ZCP || 2011.5 ///M3 Sedan || 2007 ///M Coupe || 2008 550i Sport || 2006 ///M3 ZCP || 2008 X3 3.0si || 2006 325i || 2003 Z4 3.0 Roadster || 2003 330ci || 2002 325i |
12-20-2010, 01:38 PM | #13 |
Wellee
14
Rep 64
Thanks for all the responses; you guys are a great help. As long as I didn't mess up the break-in, I won't worry about it. The manual says to vary engine speed, and I figured idling for awhile is detrimental. Had I known, I would've turned the car off.
Anyhow, I just want to get the most out the car during my 3-year lease! |
12-20-2010, 01:42 PM | #14 |
Rep 917
-09 e92 SPACE GRAY/// m3 w/ m-dct!
-06 E46 JET BLACK/// m3 6MT! |
