02-09-2011, 09:32 PM | #1 |
Rep 700
What is the max negative camber we can achieve on stock cars?
What is the max negative camber we can achieve on stock cars? Does that differ if the car is lowered with springs?
Anyone with ZCP, and max camber setting?
I apologize for spelling mistakes up front, they are a result of multitasking.
02-09-2011, 09:52 PM | #2 |
Rep 229
I managed to get -1.3 in stock form with pins removed. One side could go a bit more, but I kept it even. I now have -2.0 with Dinan springs and camber plates.
02-09-2011, 09:53 PM | #3 |
Moderator
675
Rep 4,737
Probably -1.4 if you remove the guide pins on stock springs, -1.8 with lowering springs (depends on which one) and pin removal.
The lower you go, the more negative camber you get at "normal position". |
02-10-2011, 08:42 AM | #4 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
-1.3 to -1.4 with stock springs after removing the pins. This is what I got with my first e90. You will get slightly more with lowering springs.
The Dinan camber plates will give you all the adjustment you want. I'm currently lowered with Dinan springs and camber plates. I have -2.0 in front.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
02-17-2011, 09:27 PM | #6 |
Rep 700
Nice! Thank you. Perfect.
02-23-2011, 05:37 PM | #7 |
Rep 1,424
2011 ZCP here. If I go with -1.7 in the front......what do i adjust the rear too? Or should rear be left alone? Is an alignment needed after pulling the pins and maxing out the front?
02-24-2011, 03:43 AM | #8 |
Rep 178
Yes alignment is needed if you pulled the pins and maxed out the front camber, it would cause the car to "toe out".
02-24-2011, 02:38 PM | #9 |
Rep 436
I had an alignment done this morning at the dealership. I'm on the Eibach pro kit. Looking at my printout now, here's how it reads
Rear Camber -2.04 (left) -1.53 (right) Toe .05 (left) .05 (rear) Front Camber -1.53 (left) -1.33 (right) Toe .05 (left) .02 (right) |
02-24-2011, 03:42 PM | #10 | |
Sexual Philanthropist
Rep 319
On stock suspension with pins pulled I was able to get -1.8 LF , -1.9 RF, -2.1 LR, and -2.2 RR. I'm running zero toe in the rear and 1mm out in the front.
2011 E92 M3 AW/SC DCT, ZCV
bought 11/10 sold 9/11 |
02-28-2011, 02:40 AM | #11 |
JOSH SHOKRI.
524
Rep 5,881
Drives: 991 GT3RS, 964, Raptor
I'm on KWs.. I think I'm a -2.2 I have to chcek..
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict |
