02-24-2011, 01:11 PM | #1 |
Professional Trophy Husband
25
Rep 150
MS-8 Tuning Questions
Thanks to Technic's wiring harness (awesome ) and A LOT of his time answering my questions, I finally got my JBL MS-8 installed and sounding pretty good. My definition of pretty good is approximately 1 million times better than the OEM six speaker hifi system. I have also upgraded the OEM subs with Kicker SSMB8's (again, thanks to Technic, and jtsherri for the spacers). I'll do a full review of that a little later, for those who might be interested.
The Kickers are definitely giving me more bass than I had before, but a lot of that seems to be drowned out by the exhaust sound when I'm driving. I know, I should be listening to the car instead of music, but what can I say? I like to rock when I roll. Anyway, has anyone tried doing the acoustic calibration with the engine on? It seems to me that this would be the normal listening environment. Also, is it possible to adjust the crossovers and slopes without rerunning the acoustic calibration every time? |
02-24-2011, 01:17 PM | #2 | |
Rep 6,845
Drives: 2018 Audi RS5 coupe
why calibrate when silent, you don't listen when the engine is off and no to the second item you have to recalibrate every time! |
02-24-2011, 02:42 PM | #3 | |
Rep 6
Thanks in advance. Last edited by S65E90M3; 02-24-2011 at 02:48 PM.. |
02-24-2011, 02:48 PM | #4 | |
Rep 638
That way Technic can be specific in his answers. I have a harness on the way from him at the moment. He is a top Guy and very helpful |
02-24-2011, 02:57 PM | #5 | |
Rep 6
Thanks again. |
02-24-2011, 03:24 PM | #6 |
25
Rep 150
The wiring harness is great. I just disconnected the harness coming from the head unit to the OEM amp and connected it to the Technic harness. It provides you with balanced stereo input, and clearly labeled leads to all of your speakers. You couldn't ask for an easier product to use.
02-24-2011, 03:33 PM | #8 | |
Rep 6
02-24-2011, 03:50 PM | #9 |
Rep 2,665
Drives: Goggomobil
Technic is an extremely helpful guy. I am installing the MS8 in a '06 E53 X5 and he has answered a lot of unanswered questions. His knowledge is just mind-boggling and he's so prompt in getting back to you. Top guy.
F86 X6///
02-24-2011, 04:21 PM | #10 |
Rep 6
02-24-2011, 05:22 PM | #11 | |
Rep 13,018
I would suggest that you try with the car running just for your own learning. I don't think that it changes anything, I have done it and I cannot notice any difference in my results. Changing the calibration volume level does change the results, though. You have to go thru the whole setup process and calibration if you want to adjust the crossover and slopes values. |
02-24-2011, 05:22 PM | #12 |
Rep 13,018
02-24-2011, 05:24 PM | #13 | |
Rep 6
02-24-2011, 05:38 PM | #14 |
Rep 13,018
02-24-2011, 06:11 PM | #16 | |
Rep 13,018
02-25-2011, 03:14 AM | #17 |
8 tracks of madness
62
Rep 2,735
02-25-2011, 01:33 PM | #18 | |
Rep 2,339
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
02-25-2011, 01:45 PM | #19 | |
Rep 13,018
More here: http://www.jbl.com/resources/Brands/...al/MS-8_OM.pdf |
02-26-2011, 01:45 AM | #20 |
8 tracks of madness
62
Rep 2,735
Hey Billy,
Check out the build logs on DIYMA. Bing just put up a thread for an E90 335d he just did using all Morel drivers, Mosconi amps and an MS-8. He's dOne 9 MS-8 builds now so he's got quite a bit of experience with them now. He also found a new replacement for the OEM subs. Audio System has an drop-in 8" complete with integral mounting adapter. |
02-26-2011, 11:08 AM | #21 | |
Rep 2,339
"for 99 percent of my customers, its a godsend, quick easy tuning in 10 mins...but for many of the members here on diyma who want to fine tune their own stuff...i would look elsewhere" I see that being said a lot and that's what keeps me on the fence between the MS-8 and the BitOne. The size of the MS-8 doesn't help its cause either but prices keep getting lower and lower to the point that it may be worth a try and if it doesn't work out just get rid of it.
02-26-2011, 11:54 AM | #22 |
Rep 13,018
IME with both the bit one.1 and the MS-8, the MS-8 wins my vote just because the way it uses its Logic7 processing to get the best of the center channel and thus the whole front stage.
I never was able to even come close to that effect with the bit one.1 manual tuning. Other than this, I can get all the midbass and overall adjustabiliy that I need and then some with the MS-8 once I understood how all the manual adjustments influence each other. So that's a draw with the bit one.1. |
