02-28-2011, 11:50 PM | #1 |
Rep 263
S65 - why no flat plane crankshaft?
Sometimes I wonder, it would sound insane, less nascar.
2011 E90 M3 ZP2 ZCV ZCW ZCP (for teh fastAr)
2005 LGT, AVO380 Turbo, a zillion other mods, ECU tuning by me. |
03-01-2011, 12:07 AM | #2 |
Rep 4,567
Not sure about the production cost deltas between the two. It strikes me as being negligable, as the only major component difference is the shape of the crank and the lack of counterweights. But, I'm by no means an expert in this department...
That said, I think the primary reason for BMW going with a cross-plane crank design is because it produces less vibrations and is inherently more balanced than a flat-plane crank, which makes the car much more livable for its target audience. At any rate, here's the P65-equipped (flat-plane crank) ALMS M3:
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
bigjae19761580.00 |
03-01-2011, 03:31 AM | #3 |
Rep 10,407
Cross plane has improved NVH (noise vibration and harshness) over the flat plane.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
sviswan26.50 |
03-01-2011, 08:33 AM | #4 |
Moderator
7525
Rep 19,368
Some more good discussion can be found in past threads too:
http://www.google.com/search?q=site%...com+flat+plane |
03-01-2011, 07:57 PM | #5 |
Rep 5,012
It's a lot cheaper to produce man . That's exactly how V8s started life back in the late 1800s. It was until the 1920s that advance in manufacturing techniques gave birth to the cross-plane crank. I definitely like the sound of the S65 better over the F430, even with an aftermarket exhaust (they sound like crap stock IMO).
03-02-2011, 09:36 AM | #7 |
Rep 2,528
So the engineers should design an engine around sound rather than function?
Ok
"But resist we much; we must; and we will much; about that be committed." ~Rev. Al Sharpton 2010 E92 M3|Silverstone II|M-DCT|NCSW|2MT|ZCW|ZPP|ZTP|302|507|Gas Guzzler Tax |
Cruise'n71.00 |
03-02-2011, 10:56 AM | #9 |
Rep 961
03-02-2011, 11:01 AM | #10 |
Moderator
7525
Rep 19,368
You are thinking of a horizontally opposed engine layout (often called a "boxer"). The thread is about a flat plane crank. It adds nothing to the dimensions of the engine; it just changes the shape of the crankshaft.
03-02-2011, 12:37 PM | #11 | |
Rep 319
Drives: 10 X5 M/05 F430/12 CTS-V Coupe
10 BMW X5 M Silverstone w/Black on Black interior - Loaded
12 CTS-V Coupe Thunder Gray - Loaded 13 Ford GT500 (650HP Priceless!!!!) as soon as can be delivered 05 F430 F1 - Giallo 08 BMW M3 Interlagos Blue Metallic - DCT (Traded) |
03-02-2011, 01:15 PM | #12 |
Rep 5,012
A matter of opinion; I like the M3's more refined engine sound better , but at the same time, nothing sounds like a Ferrari. I like the sound A LOT better from the inside than outside, however. Have the stock exhaust but with FabSpeed pipes (no valves) and tips, and it's too loud IMO, plus drones like hell with the top up ('06 F430 Spider here). Need to get to a rally to hear all aftermarket options, but read higher-pitched exhausts drone less. I see you also have the same handle at Fchat . But they're TOTALLY different cars; don't mind the noise on the F-car, but I do on the M3 (stock exhaust here). Later.
03-02-2011, 01:30 PM | #13 |
Lurker
78
Rep 812
03-02-2011, 08:53 PM | #14 | |
Rep 263
Unequal exhaust pulses FTL....
03-03-2011, 05:29 AM | #15 |
Rep 1,282
Cost and NVH. More M3's than F430's are sold. I still wish my M3 had a FPC.
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune Alpina B8, zero performance mods |
07-18-2023, 12:21 PM | #16 | |
Rep 185
Packaging in small engine bays much easier. |
07-18-2023, 12:23 PM | #17 |
Rep 490
Drives: 2009 E93 M3 DCT
09-02-2023, 12:56 AM | #18 |
Rep 185
But this the reason now or then?
But that's why the new X5 m60i S68 has now a flat plan crank. The bonnet and front of the car is lower isn't it. |
09-03-2023, 05:43 AM | #19 |
Rep 161
The flat plane design has a different and more pronounced vibration signature. When Ford used it in the Mustang, several early production cars vibrated enough to break the oil cooler lines and catch fire. I read a long article about the FPC in the C8 Corvette and it stated that they put as much engineering into the motor mounts as they did into the engine. The C8 engine and transaxle mounts are designed to separate the engine vibration from the chassis, not to hold the engine still.
Cruise'n71.00 |
09-10-2023, 09:19 AM | #20 | |
Rep 185
The new S68 M60i models that replaces the old N63 M50i models. Was surprised nobody has mentioned the engine being more course at all. Presume BMW too have engineered the mounts to absorb the vibrations? |
