03-01-2011, 11:54 AM | #1 |
Rep 628
Q: Hard Drive Upgrade
What Hard Drive comes with the M3 for 2009 and up? And is it possible to upgrade that hard drive to maybe a faster SSD? In theory, it should be possible, but has anyone ever done it?
03-01-2011, 11:58 AM | #2 |
Rep 8,952
Not sure if it's worth an SSD upgrade, probably won't make the system over faster. But an upgrade to the hard drive for more music/data stored might be a good idea. I wonder if Alekshop knows anything about this. They seem to do a lot of retrofit work! Check with them!
03-01-2011, 12:01 PM | #3 |
IG@i.am.wah
2780
Rep 3,815
Drives: M2 CS
Doesn't sound like it would be an easy job. I would think you need special software just to format it and install other software on it so it can be used in the car. I just put an SSD in my 3yr old macbook pro and it feels like a new computer... probably faster than a new non-ssd computer. Amazing. I'm never going back.
03-01-2011, 12:03 PM | #4 | |
Rep 8,952
03-01-2011, 12:15 PM | #5 |
Rep 635
You should just be able to take an image of the stock HDD and put that image on the new SSD. I would have to guess that its some proprietary drive not just a 2.5" notebook drive installed in there though.
03-01-2011, 12:22 PM | #6 |
Rep 309
There are a few possible hurdles, though I'd love to see this done:
- physical access: shouldn't be an issue, since they probably fail and BMW wants the local techs to be able to replace them without too much trouble - physical connection: the drive is probably SATA, but there's a possibility that it uses a custom physical connector. I think this is pretty unlikely however. - firmware: this would be the biggest hurdle. The drives could have a customer firmware (this happens a lot int he enterprise IT segment, vendors can sometimes put custom firmware on their HDs for various reasons). This would be tough to duplicate for a replacement drive. - partitions: pretty easy to duplicate these with a Linux box, then you'd expand the partition that contains the free space The drives may be SSDs already. In a car, it's a good idea and 64-128GB SSDs aren't expensive. I doubt they are top of the line models either. |
03-01-2011, 12:35 PM | #7 |
Picking fights with sharks
Rep 133
If you take off the trim from your CCC you can actually see where the HDD sits. It's a small slot that looks the same as the PS3 HDD slot. Most likely a standard 2.5'' laptop hard drive in there.
2011.5 M3 Coupe DCT
2007 Lotus Exige S 6MT 2005 545i 6MT Fast is subjective. |
03-01-2011, 01:49 PM | #8 |
Rep 15,818
it boots up almost instantly and responds quickly
i don't see how (or why) you'd want to make it faster more storage space would be nice though
03-01-2011, 02:00 PM | #9 |
Rep 741
i wouldn't screw around with it if I were you
2010 BMW M3 vert with DCT & Akra (sold)
2012 Porsche 911 Turbo S |
03-01-2011, 02:05 PM | #10 |
Rep 1,530
with an M3, it's more about Drive Hard than about Hard Drive!! I think.
2011 E92 JB/BL/DCT--->80K Miles
2015 F80 SS/SO/DCT?->28K Miles 2015 Porsche 911S |
03-01-2011, 02:13 PM | #11 |
Rep 4,381
03-01-2011, 02:57 PM | #12 |
Rep 628
Yes, it would be definitely more for the space vs speed, but a little speed wouldn't hurt. I was thinking maybe if I bring my hard drive into the dealership, maybe they have software that can do it for me. Or if someone comes up with a plan, that would be awesome
03-01-2011, 03:43 PM | #14 |
Rep 1,769
Drives: 2011 E92 M3 ZCP
Doesn't sound like a good idea to me. SSD won't help if the CPU of the BMW system is slow already.
'12 CLS550 Palladium Silver - loaded
'11 E92 M3 ZCP - SG/B-EXT/CF, M-DCT, loaded '11 E93 328i, BSM over Saddle Brown, sport, loaded '08 550i M-Sport, Carbon Black (Gone but not forgotten), '06 W211 E55 AMG (Gone, miss this animal),'01 E39 540i Sport |
03-01-2011, 03:58 PM | #15 |
Havin' a blast!
125
Rep 4,847
Not saying OP should do this or not, but generally speaking, even the slowest CPU is faster by far than mechanical hard drives (that have spinning platters on spindles & needles hovering over them). And, if you use SLC SSD, instead of MLC SSD, whoa.
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
03-01-2011, 04:11 PM | #16 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
well based on those PDFs those HDs are repaceable
and i think it's safe to assume it's a SATA HD so all you need is a way to clone the existing partitions to the new drive and expand the audio partition to fill the drive |
03-01-2011, 05:01 PM | #18 |
Rep 1,153
I'd be interested in a SSD upgrade, not because of speed, but because it's silent and a lot more heat and shock resistant than a hard drive. I'm very curious to see if the migration is possible.
03-01-2011, 05:07 PM | #19 | |
Rep 2,464
That being said, it makes more sense to have SSD then a regular HDD in a car due to all sort of vibrations. Although, BMW is not stupid, they may already be using a suitable HDD.
2011 MINI Cooper S
previous cars: E92 M3, Z4MC, Z4 Roadster, E36 328 Sedan |
03-01-2011, 05:10 PM | #20 |
Lurker
78
Rep 812
I'd like to know if you're able to do it.
Generally it just gets you more storage since the CPU in the CIC is probably slower than the hard drive interface so most people just cram a bigger memory stick in the USB port. |
03-01-2011, 09:06 PM | #21 |
Rep 636
Doesn't the iDrive system use a extremely high compression rate on the audio files? If this can not be changed, then upgrading your HDD for more storage is just a waste. just buy a 160gb iPod, that is if you have the ipod option. If not, USB sticks come in VERY large capacities.
PM alekshop. I do suspect that the iDrive would need a particular drive, running particular firmware. This allows BMW to charge through the nose for iDrive repairs. |
03-01-2011, 09:16 PM | #22 | |
Rep 13,018
