      03-19-2011, 12:11 PM   #1
e82n54
e82n54's Avatar
Drives: '09 135i 6MT Alpine White
How remove panel behind rear seat headrests
Can anyone tell/show me how to remove the black fabric panel behind the rear seat headrests. It's the one with the speaker covers.
Thanks!
      03-20-2011, 10:53 PM   #2
e82n54
e82n54's Avatar
I got it! Not sure if anyone cares, but I figure I can at least explain the process in case someone is curious in the future.
I had to dismantle pretty much the entire rear end of the interior and trunk to get this panel off!
The panel is called the rear window shelf. Here's a description of the part: http://www.realoem.com/bmw/showparts...19&hg=51&fg=40
1) fold down the rear seats
2) remove the side leather seat bolsters (under the rear seat belts) - there's only 1 clip at the top which requires a lot of force to pull it out
3) remove the trunk rubber weather strip
4) remove the big hard plastic piece in the back of the trunk
5) remove the trunk lining on both sides
6) remove the interior plastic panels above the rear seat belts
7) remove the plastic seat belt covers at the top of the rear seat belts
8) finally, the rear fabric panel with speaker covers can be unscrewed (the speakers are wired and screwed into this panel, and a wire on each side can be unplugged to free the panel)
It was a lot more trouble than I expected, but I'm pretty new to removing interior panels and parts.
      05-21-2011, 10:44 AM   #3
texasmojo
texasmojo's Avatar
Drives: 2008 128i automatic
Thanks.
      05-21-2011, 12:43 PM   #4
Sarracino89
Sarracino89's Avatar
36
Drives: 128i Black on Black
2011 128i  [0.00]
Just curious as to why you wanted/needed to remove that panel?
      01-15-2012, 08:52 PM   #5
Backflush
Drives: 2010 135i
Here are a couple of additional details
Originally Posted by Scuderia000 View Post
6) remove the interior plastic panels above the rear seat belts.
This is the corner pieces by the rear window that has a small rectagular piece with "airbag" on it. Remove this piece and behind it is a T20 screw. There are two fasteners holding at the top front and rear. Just give it a tug with your plastic panel removal tool to unlatch them and the slid it forward.
7) remove the plastic seat belt covers at the top of the rear seat belts.
There are two fasteners at the top of the seat belt cover and a hex screw at the bottom. Remove these and the pull the cover away from the window to unhook it from the rear shelf.
Remove the rear speaker covers and speakers. Remove the small plastic covers on the child seat anchors and remove the bolt inside it with a T40. Then on the front of the shelf there are 5 plastic fasteners that need to be removed. Pull foward on the front edge of the shelf to lossen it from the metal edge and lift it over the rear seat latches. You can then pull it towards you to remove it.
      01-21-2012, 05:50 PM   #6
ktkilroy
135i M Sport
ktkilroy's Avatar
United Kingdom
Drives: 135i M Sport
Thanks a lot will b handle for tinting ma rear window
      12-26-2019, 08:36 PM   #7
Digger Dave
Digger Dave's Avatar
Australia
Drives: IM, F150 Tremor, Westfield,
Great Helped me
Great Helped me
Rgds
Dave Thirlwall
There you go more negative waves, have a little faith.
1addicts
