BMW M3 Forum (E90 E92)
EXXEL Distributions
      03-22-2011, 11:22 PM   #1
Black Stallon
Quemando Carretera
Black Stallon's Avatar
Drives: E90 M3
Self-Alignment done, Need camber answers?
So Im a UTI student and I did an alignment to the car (Stock suspension) like 1 month ago, like 3 weeks later I found out that the inside of the driver side tire is worn out to the nylon thread. WTF... we align this thing wrong so I bought new tires and align it today. We did camber/toe in rear and toe in the front it was all out of specs according to the machine.
But the problem is that we coulndt adjust camber because supposely u need a special BMW tool to adjust camber from the top of the car. Im not very familiar with this process. Do I have to take this to a BMW dealer to align!?
Or is this not the true way to adjust camber on our cars?
The way the tire was worn led me to believe that camber was too negative on the driver side.
      03-22-2011, 11:44 PM   #2
bunnn
bunnn's Avatar
86
Drives: like a grandma
I'm no expert at this, but the shop I was used to go to did only Audi/VW/Porsche ..they had absolutely no problem aligning my car. I watched them align the car(I usually hang around back to learn) and I didn't see anything special that they used, nor did they get from the top of the car. I can't imagine there was a BMW specific tool.
Cheers
Ben
      03-22-2011, 11:47 PM   #3
rzm3
Moderator
rzm3's Avatar
675
Drives: E92 M3
Are you talking about the front wheels? Simply loosen the three bolts on the strut tower. Adjustment is very limited, however. (ignore comments in the picture)
      03-23-2011, 08:42 AM   #4
elh0102
Drives: 2009 335i coupe
There is very little provision for camber adjustment in the stock design, not enough to cause the result you describe. Your problem is in the toe adjustment.
      03-23-2011, 12:58 PM   #5
Black Stallon
Quemando Carretera
Drives: E90 M3
ok, So you do adjust it from the top. I'll check my tires in a week, to see if theres any excessive wear. In case I have to do this myself, I loosen the 3 bolt on top and then how would u adjust camber a bit more positive for example?
      03-23-2011, 02:12 PM   #6
elh0102
Loosen the three nuts and push the top of the strut in for negative, pull out for positive. There is only 1.0-1.5 degrees of total movement, not much. The strut will move easier if both sides are lifted to the point of removing most of the weight from the suspension, almost off the floor. If you jack one side only, the stabilizer bar will place the suspension under a lot of tension, making movement in one direction very difficult. Assuming your suspension has not been damaged or altered, you should not need any more positive camber. In fact, full negative by the factory adjustment is rather routine, and not nearly enough negative to result in premature tire wear, which is almost always a toe issue.
      03-23-2011, 07:15 PM   #7
VictorH
Drives: '09 M3
Yeah evidently the "special tool" my BMW dealer used to set the camber was a big old screwdriver because after I got my car back I pulled off the EDC cover and could see where they wrenched the suspension and slipped off bending the upper washer. Nice service.
      03-24-2011, 06:33 PM   #8
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
remember that unless you pull the pin, there is zero adjustment.
      03-24-2011, 06:34 PM   #9
kitw
kitw's Avatar
471
but if the inside of your tires are wearing, that is more than likely toe, not camber. A bit of extra camber won't wear out tires in a few thou miles.
      03-24-2011, 11:06 PM   #10
Black Stallon
Quemando Carretera
Drives: E90 M3
thanks for the answers,
      03-25-2011, 08:19 AM   #11
JJM335
Drives: 2008 E92 M3
2008 E92 M3  [0.00]
+1
Rears on my wife's Z4 wore down to the cords in 8k miles because toe was incorrect.
      01-01-2015, 02:29 AM   #12
E92M3GT
Drives: E92 M3
Can someone please show the pin ?
      01-01-2015, 11:51 AM   #13
kenwelch
Drives: 2008 E92 M3 M-DCT & 2017 440GC
The Hunter Alignment equipment that you have at UTI includes detailed digital photo and video instructions for each vehicle listed in the specification set-up page. You can access the help procedures and specific BMW chassis height and weighting requirements during alignment. Just input your vehicle year, make, model and then you will have access to the information.
This is a link to the Hunter Engineering Alignment Video Library that will help during your alignment class:
http://www.hunter.com/videos/index.cfm?cat=2
1. Ask the alignment instructor when the equipment was last calibrated. IF the alignment equipment is out of calibration then you will not have a correct alignment when "finished". This has happened in my automotive classroom.
2. Find a BMW STEP program student that will help you with the BMW specifics for your vehicle. There might be BMW STEP training on your UTI campus.
3. Google this for the 4th Gen Chassis manual:
4th Generation M3 Chassis Dynamics
OR
http://prodcds.bmwuniversity.com/lib...20Dynamics.pdf
Enjoy the training.
      01-01-2015, 12:00 PM   #14
kenwelch
Here is a link about the pin:
http://www.e90post.com/forums/showthread.php?t=358576
      01-01-2015, 12:00 PM   #15
SenorFunkyPants
SenorFunkyPants's Avatar
United Kingdom
2511
Drives: 2019 M5
http://www.m3post.com/forums/showthread.php?t=521177
Includes pictures.
      01-01-2015, 11:24 PM   #16
E92M3GT
Drives: E92 M3
Originally Posted by SenorFunkyPants View Post
Perfect, thanks !
      01-02-2015, 01:05 AM   #17
JAJ
Drives: 2014 Shelby GT500
Your camber is probably fine. It sounds like it's time to learn the old racer's trick of "stringing" your car. Once you figure it out, it's amazingly accurate and totally reliable.
m3post
