03-30-2011, 11:01 AM | #1 |
BTC maxi
222
Rep 1,124
Never ending DSC error, possible lemon
I have been getting a DSC error intermittently over the past 2k miles or so. yesterday was a good example of what the triggers might be. it was about 50 when i put it in the garage and 26 when i left this morning. it never triggers while driving but only after start up and within 1-100 feet of driving. it has been in the shop twice now. the first time they replaced the idle valve (which i thought was cleared up back in 2009), and the second time they replaced the actuator rod for the idle vale control. today i am dropping off the car again for the third time for the same identical reason.
In MA the lemon law is same trouble 3 times or 15 days with out your car, at least from what i have read. i purchased the car in RI so do i have to use their lemon law? will i lose money on a buy back, anyone have a similar story? 2011 E90 M3 ~5K miles UPDATE: they opened up a puma case and bmw gave them the green light to reprogram the car everything has been working fine since, knock on wood. UPDATE: 4.3.2012 - 12,000 miles no return of issue during last winter, i think its safe to say that the coding did the trick. Last edited by audioMeth; 04-03-2012 at 05:34 PM.. Reason: update |
03-30-2011, 11:37 AM | #3 |
Rep 959
I am also in MA and have gotten the DSC message about six times over the last two years. It has always been on a cold morning or starting in an icy spot. It has never come on while driving and goes away afterr a restart. I have always written it off as a glitch and wouldn't think of lemoning the car over it.
Have you had any direct problems from the DSC error or any serious issues with the car?
03-30-2011, 12:22 PM | #4 | |
BTC maxi
222
Rep 1,124
once i restart it goes away, i also wrote it off at first as a gitch but it comes on multiple times a week. |
03-30-2011, 03:43 PM | #5 |
Rep 959
It sounds like yours happens way more often. I have noticed if I am in a real hurry and backup just after starting the car I am more likely to get the error message. Also, I have never seen it when temps are above 50.
I hope you can get it sorted out.
