New 2009 2010 BMW Z4 - ZPOST
      04-07-2011, 01:12 PM   #1
spankjelly
Drives: 2001 M Coupe
135i brakes on the E89 z4
I don't think there is an argument that these certainly look better. I know the 135i kit uses 6 piston brembo manufactured fronts. (For those of you that don't know, the stock 135i front brakes are identical to the yellow BMW "performance brakes", which we already know fit).
Has anyone thought of putting a pair of 135i brakes on the E89?
      04-23-2011, 02:40 PM   #2
04cbm3
04cbm3's Avatar
Drives: E46 m3
Not trying to be an asshole but what's the point. Why would you want to do that are they better than the brakes on the 35i?
      04-23-2011, 04:17 PM   #3
Constant.S
Resistance is futile...
Constant.S's Avatar
54
Drives: BMW Z4 E89(N54)
Maybe you're talking about the 1M brakes? Cause if that's the case yes. I want those brakes too...
An ounce of performance is worth pounds of promises.
      04-26-2011, 03:00 PM   #4
css
css's Avatar
25
Drives: Macan S
135i brakes are identical to bmw performance brakes which is 6 piston..i think these would be better than the 35i brakes?
      04-26-2011, 10:08 PM   #5
Land_Shark
In The Flesh
Hong Kong
23
Drives: Z4 sDrive 35i
Are we talking about the 1M or the regular 135i ???
If you are talking about the 135i, You mean the calipers are 6 pistons, but still on a regular disk/rotors (NOT Cross-drilled OR slotted rotors)
Why don't you just change the Calipers than?
      04-27-2011, 01:35 AM   #6
taYab
taYab's Avatar
Drives: '06 E60 '09 E89 '14 F25
135i does not fit perfectly on our car.
3 series BMW performance brakes fit on ours.
2006 E60 Gone!
2009 E89 Gone!
2014 F25 !!
zpost
