BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Suspension | Brakes | Chassis | Handling
EXXEL Distributions
      04-07-2011, 04:17 PM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
>> HP Autosport << Stoptech Big Brake Kit - EXCLUSIVE Pricing for M3 Post Members
Big Brake Kits give your vehicle that Supercar look and feel, and exceed stock performance in two areas. First, larger rotors increase heat capacity. Second, stiffer calipers and stainless steel lines reduce system compliance.
The key, however, is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio. If the brake upgrade you select adds too much front torque (as many do), you reduce your car's ability to utilize the tractive capacity of all of the tires to the maximum practical extent (even on ABS equipped cars) and you therefore create performance sacrifices. In addition, too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, which limits a driver's control of brake input on the race track.
Advantages of StopTech over other brake upgrades:
-Shorter Stopping Distances
-Better Brake Modulation
-Firmer Brake Pedal
-Less Brake Fade
Feature Benefit Summary:
-Balanced Brake Upgrades™ with optimum brake bias offer the shortest stopping distance with the best pedal feel
-Our patented AeroRotors® with the best airflow available result in better cooling, less fade and longer rotor and pad life
-The stiffest aftermarket calipers with patented bridge result in better clamping under hard braking and less pad taper
-Track testing of new applications ensures optimum performance
For those looking to put their car on a diet:
4 lbs on the front rotors.
2 lbs on the front caliper and bracket.
3 lbs are on the rear rotor
1 lbs on the rear caliper.
The key here isn't about the weight savings but the increase in the
amount of heat capacity available.
Application and Pricing
Front 15 inch BBK
ST-60 6 Piston Calipers
Floating 380x32mm AeroRotors
MSRP - $3695.00
Front 14 inch BBK
ST-40 4 Piston Calipers
Floating 355x35mm AeroRotors
MSRP - $2995.00
Rear 14 inch BBK
Floating 355x32mm AeroRotors
MSRP - $2895.00
Additional Price Info
Red / Black / Silver Calipers - No Additional Cost
Blue / Yellow / Gold - $200.00 per axle
Slotted Rotors – No Additional Cost
Drilled Rotors - $100.00 per axle
-For gold, blue, silver or yellow calipers, please add 4 weeks for lead time.
Please shoot us a PM for your M3Post Member price!
      07-21-2011, 04:53 AM   #2
IMG's Avatar
Drives: E36 M3 Track car,Ess E90 M3 DD
PM sent
      07-23-2011, 09:13 PM   #3
mainstray
NSDQ
mainstray's Avatar
Drives: E92 M3
2008 E92 M3  [0.00]
please pm pricing for:
Rear 14 inch BBK
Thanks!
      09-05-2011, 05:30 PM   #4
HP Autosport
Drives: F80 M3
Rear 14 inch BBK
Thanks!
PM sent!
      09-05-2011, 05:42 PM   #5
montreal red
chris
montreal red's Avatar
Drives: White Boat
pm me pricing for replacement pads for my 380mm/355mm stoptech bbk. need it shipped to upstate NY 12919.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      09-11-2011, 12:51 PM   #6
HP Autosport
Drives: F80 M3
PM sent!
      10-13-2011, 12:17 PM   #7
CFENSTY
CFENSTY's Avatar
Drives: 2009 M3/Ferrari 360 Modena
Stoptech BBK
Please PM price for 380/355 setup for my 2009 e90 m3. Black calipers with slotted rotors and street performance pads. Car is dual purpose daily driver / HPDE car. Thanks
      02-16-2012, 01:48 PM   #8
TimeAtk
Drives: Alpine e90 M3
PM me price shipped to 91007 for fronts only 6 piston thanks! 16 inch
      04-18-2012, 12:34 AM   #9
HP Autosport
Drives: F80 M3
PM sent!
      05-01-2012, 08:11 AM   #10
ee8
Portugal
Drives: E92 M3
2008 BMW M3  [6.40]
PM for Trophy 380mm, slotted, front only shipped to Portugal. Thanks
      05-01-2012, 05:51 PM   #11
HP Autosport
Drives: F80 M3
PM sent for sport and Trophy.
      08-23-2012, 09:07 PM   #12
yz490
Drives: 08 E90
If you offer the 355mm front only slotted kit, (no brake lines needed), pm me a price to 20818. Thanks!
      11-15-2012, 08:14 PM   #13
HP Autosport
Drives: F80 M3
PM sent!
      03-05-2013, 12:24 AM   #14
E90335iflyer
E90335iflyer's Avatar
Drives: Audi Q5,BMW 335i, Porsche GT3
Location: JFK, SFO, LAX, NRT, TPE, PVG, HKG, LHR, ATH, MUC, FRA, SIN
PM for 380 front kit only with slotted rotors.
      07-03-2013, 12:37 PM   #15
HP Autosport
Drives: F80 M3
Retail price increase of $300 per axle affective 7/1.
Your discount % does not change with us so PM us for best prices!
      01-15-2014, 02:54 PM   #16
HP Autosport
Drives: F80 M3
20% off of retail!
      10-01-2014, 02:10 PM   #17
HP Autosport
Drives: F80 M3
PM for best prices!
      10-01-2014, 02:45 PM   #18
dbyrd
DSC Off!
dbyrd's Avatar
304
Drives: 2012 E92 M3 6MT ZCP
Please PM best price for ST-60 slotted front to 75218.
Thanks, Harold.
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
      01-07-2015, 11:28 AM   #19
HP Autosport
Drives: F80 M3
bump
      01-27-2015, 09:07 PM   #20
Zzhou
Zzhou's Avatar
Drives: 2012 E92 SSII ZCP DCT
pm price for ST60F/ST40R with slotted in Red and Blue thanks
AA Green Filter/AA Pulley/AA catless X-pipes/AA signature exhaust/AA TUNE/TMS studs/Project Kics R40/R888/VOLK ZE40/ST60,ST40 BBK/MCS 2WAY NR/Vorsteiner GTS5 Bumper/APR GT250/APR SPLITTER
      04-18-2015, 12:15 PM   #21
HP Autosport
Drives: F80 M3
bump
      06-12-2015, 02:02 AM   #22
HP Autosport
Drives: F80 M3
bump
m3post
