04-25-2011, 03:10 PM | #1 |
Rep 531
Bleeding Procedure: Brembo BBK
Hey guys,
Just wondering what the procedure is for bleeding Brembos. I know you start furthest from the fluid reservoir and work your way up, but the brembos have two valves per caliper. Which one do you bleed first? Thanks!
Gone but not forgotten...2009 E90 Le Mans Blue M3 6MT De-Chromed, Rogue SSK, Brembo BBK, Eibach Pro Kit, Eisenmann Race Black, MS Filter. 1998.5 Titanium Silver E36 M3 Coupe NASA GTS2 Race Car.
04-25-2011, 07:26 PM | #3 |
Moderator
675
Rep 4,737
From StopTech manual:
Note: The calipers and lines will need to fill with fluid, quickly draining the master cylinder reservoir. Keep a close watch on the fluid level when initially bleeding the system. Do not allow the master cylinder reservoir to run dry, and to draw in air. Doing so may result in the brake system needing to be serviced by a certified brake technician. Bleed the brake system, using an 11mm box wrench, to loosen the bleed screws. The sequence for bleeding the brakes should be: 1. Right outboard bleed screw 2. Right inboard bleed screw 3. Left outboard bleed screw 4. Left inboard bleed screw Though a torque wrench is not typically used on bleed screws, as a reference, the torque for bleed screws should be approximately 100-140 lb-INCH. After initially bleeding the system, gently tap the caliper body with a mallet to dislodge any small air bubbles, then re-bleed the brakes. After bleeding, apply constant pressure to the brake pedal, and check all connections - including the bleed screws, and both ends of the brake line - for leaks. Warning: Brake fluid will damage most painted surfaces. Immediately clean spilled brake fluid from any painted surface, including the caliper. Though caliper paint is designed to resist harsh chemicals, prolonged exposure will damage the finish. |
04-26-2011, 12:38 AM | #4 | |
Rep 961
If "yes", then follow the order in the Stoptech instructions but bleed each caliper's outside bleeder (until you get clear fluid with no bubbles), then the inside, then the outside a second time, then the inside a second time. Between each cycle, tap the caliper body with a soft mallet - preferably hard plastic. Once you've done all four calipers, the go around the car again in the same order, and do two or three strokes on each bleed screw to catch any lingering bubbles. Usually you won't get any bubbles on the second trip around the car, but it's quick and easy when the wheels are already off. On the other hand, if it's just a regular bleed after a hot day of use, then just follow the Stoptech instructions. The mallet is optional. The M3 has a stepped master cylinder, so the front brakes push though more fluid than the rears per stroke of the pedal. Check your fluid every ten or so strokes at the back, but move it up to every six or so at the front. The fronts push through A LOT of fluid every stroke, and running dry in the reservoir can't be fixed without a trip to the dealer to bleed air out of the DSC and ABS system. |
04-26-2011, 10:46 AM | #5 |
Rep 531
This is just some additional work being done after the install... the pedal still feels a little spongy. My stock brake pedal feel was better than this and I had SS lines with new pads. I would imagine that it should not be this way.
I also have had the car in to bleed air out of the ABS system already. Are the ABS and DSC systems the same when it comes to bleeding air out of the systems? I mean if you bleed one (ABS) are you also bleeding the other (DSC)? Or is it a different procedure for both?
04-26-2011, 07:20 PM | #6 | ||||
Rep 961
No. |
04-27-2011, 01:58 PM | #7 |
Rep 531
Hmm. I did not take it to a dealer to have this done. I took it to a non-dealer. They said that is what they did. I'll have to ask them if they have the tool.
Thanks
04-27-2011, 02:00 PM | #8 |
Rep 531
I am just using the pads that come with the Brembo BBK kit for street use and then DOT 4 fluid. I couldn't tell you which brand though.
I have hawk pads for track use and have not had a chance to try them out... 3 weeks and counting...
04-27-2011, 11:40 PM | #9 | |
Rep 961
This might be part of the problem. Or they may have done the job properly. There's no way to know. Did you actually get air in the ABS/DSC system in the first place or was the ABS/DSC cleanout done as part of a flush? |
04-29-2011, 06:08 PM | #10 |
Rep 111
Stainless steel lines do not produce a better pedal feel unless the OE hoses are soft and expanding. If the new pads are not fully worn into the rotor then the pedal can be spongy even without air in the system.
