05-11-2011, 09:50 AM | #1 |
Rep 38
Is double-clutching necessary...
... for a down-shift rev-match in a 6MT? I read that double-clutching is no longer necessary on newer manual cars, especially the M3 since the gears are synchronized (no idea what that means). Is this true? If so, is it safe on the drive-train/clutch to down-shift this way?
1) Press clutch 2) Drop to lower gear 3) Rev-match by pressing gas 4) Release clutch 5) Hit gas and go. Or is there a better/proper way? Sorry for the newbish question, but I am somewhat a newb to manuals. Flame if you wish. Thanks!
Current: '10 Jet Black E90 335i
Retired: '11 Jerez Black E92 M3 w/ZCP, ZCV, ZP2 |
05-11-2011, 10:31 AM | #4 | |
Rep 2,464
If you think about gears, you're going from one ratio to another, which means they will be spinning in different rates for a given speed. So you have to make sure gears spin at the same rate via double clutching. In modern transmissions, the gears are always in contact (ie, synchronized), so you don't have to worry about this. For better explanation, refer to wiki: http://en.wikipedia.org/wiki/Manual_...d_transmission
2011 MINI Cooper S
previous cars: E92 M3, Z4MC, Z4 Roadster, E36 328 Sedan |
05-11-2011, 10:44 AM | #6 |
drop a gear and...
79
Rep 967
The DCT cars rev match.... Just sayin.
05-11-2011, 10:49 AM | #7 | |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
The last thing I drove that didn't have 1st gear synchronizers was 1974 Ford F-250 with a "granny low" 1st gear. Double clutching really only helps with the speed of downshifts. It does save a little wear and tear on the syncros, but can do some harm if done incorrectly, e.g. mismatched speeds when engaging the gear. I double clutch about 25% of the time. Usually, just to have a little fun.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
05-11-2011, 11:53 AM | #8 | |
Rep 2,464
2011 MINI Cooper S
05-11-2011, 12:38 PM | #11 |
Moderator
96
Rep 1,920
Nice vid. LOL. Triple clutch? Wtf? ROTFLMAO!
All he is doing is slipping the clutch....which will beat the sh!t out of it. The only time you need to double clutch is when driving a big-rig, or maybe when going to first.
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
05-11-2011, 03:38 PM | #12 | |
Rep 373
What about the brake? The only thing I would add is step (0) which is "press the brake with the ball of your foot," and on step (3) you rev-match by blipping the throttle with the outside of your foot while continuing to press the brake with the ball of your foot. This is heel-and-toe downshifting. It takes some practice to make it smooth, but allows for quicker deceleration than simple rev matching does, and avoids some wear and tear on your clutch. The reason you down-shift in anticipation of a corner coming up shouldn't be to slow the car, but rather to be in the proper gear for when you start to apply the gas as you turn in to the corner.
F83 M4 convertible, F15 X5 xDrive35i
Previous: E93 335i, E36 328iC, E28 528e, E21 320i |
