New 2009 2010 BMW Z4 - ZPOST
      05-13-2011, 11:10 AM   #1
ridin135
Drives: Depends on the day
Charge pipe install
Has anyone installed a charge pipe on there z4? I have been looking at it and it looks like the metal band clamps will need to be cut in order to remove it. If that's the case I think I might have to go a custom route.
      05-17-2011, 12:17 PM   #2
zzz36
Drives: lexus
you are correct that the metal band would have to be cut. Just use a dremel tool with cut off wheel and take your time, you do not want to cut the rubber tube that is on there right now since it will be reused..
zpost
