05-16-2011, 11:37 PM | #1 |
Rep 1,108
Stock non-ZCP E90 Owner: Quick Help?
Can someone please measure the vertical distance between the center of the wheel to the front and rear fenders?
I have the GC coil over kit and I am trying to ensure my car is dropped a specific amount but don't have a starting reference point. Thank you in avance. |
05-16-2011, 11:57 PM | #2 |
Rep 636
I can tell you my E92 stock, non-zcp: front is exactly 15 inches and rear is 14.25 inches. Not sure if E90 is a whole lot different. Hopefully someone with an E90 will chime in for you.
05-17-2011, 12:14 AM | #3 |
DJ Singh
Rep 32
Just checked on my car (I have 18 in wheels) just a hair under 15 (14 and 7/8) inches in the front and just a hair under 14 (13 and 7/8) inches in the back. Thats from the center of the roundel to the very edge of the fender.
Hope that helps |
05-17-2011, 03:46 PM | #5 | ||
Rep 1,108
Awesome. Thank you! It should theoretically not matter since the measurement is from the hub center to the fender. I have both 18 and 19 inch wheel. |
05-25-2011, 11:44 AM | #7 | |
Rep 1,108
Another thing I noticed is that the hardest EDC setting was too jarring on the road. The middle setting worked best. After raising the car back to 1.25" / 1.5", the stiffest setting feels fine. |
05-25-2011, 02:16 PM | #9 | |
Rep 1,108
My car has a nice visual stance. It does not look like the front is higher than the rear as the numbers would suggest Last edited by knifegun; 05-25-2011 at 06:51 PM.. |
