New 2009 2010 BMW Z4 - ZPOST
      06-09-2011, 09:26 PM   #1
ridin135
Drives: Depends on the day
Meth injection
Just curious is anyone here running methanol injection on their z4?
      06-10-2011, 03:25 AM   #2
al1
Drives: z4 35i
+ 1 and how good is the system ?
      07-29-2011, 09:26 PM   #3
ridin135
If anyone needs any tips, advice, or a review shoot me a pm.
      07-30-2011, 05:17 PM   #4
ridin135
Also if anyone is interested I could make them a pnp solution if they would like.
      08-02-2011, 09:35 AM   #5
Vintage
Vintage's Avatar
Drives: BMW G80 (MT), 718 Spyder
mine is ready for it with some upgrades that include the STETT charge pipe but we did not take the plunge.
      08-02-2011, 10:59 AM   #6
ridin135
Well worth it but I wouldn't use the stett bung location as it is to close to the throttle body.
      08-02-2011, 01:17 PM   #7
Vintage
Vintage's Avatar
thanks for the advice
      08-02-2011, 01:24 PM   #8
ttuner
ttuner's Avatar
68
Drives: z4
its only worth it if you are running software that will take advantage of the additional octane levels.
running 98 octane on a 92 octane program isnt going to do anything for you but burn money.
2011 BMW Z4 35i | FBO | VTT Stg 2+ (EK, 20T clipped)| Motiv PI| Motiv Tuned | Fuel-IT Stg 2 + inline fuel pump | Spec Stg 3+ clutch | MFactory flywheel | 606whp 575Lbs |
      08-02-2011, 02:25 PM   #9
ridin135
Not entirely true, yes you won't gain much from octane but you will be at ambient temperature while spraying which helps out alot as heatsoak is a problem on these cars. Meth is the best mod after a tune hands down, a tune should still be first on your mod list.
      10-23-2011, 04:14 AM   #10
entrepreneur177
из Кремля
entrepreneur177's Avatar
Russian Federation
15
Drives: Z4 35s, CLS63 AMG
I wonder if anything changed since the last post? Seems like **********s have a ready solution for z4.
      10-28-2011, 07:52 PM   #11
entrepreneur177
из Кремля
Russian Federation
15
Well, seems like this mod is not that good, since nobody use it.
      10-29-2011, 09:55 AM   #12
BMWM4
Drives: BMW M4
its a good mod, but its for serious modders and it almost always comes after tune downpipes and dci, so since there are no downpipes for our cars yet people aren't to serious about modding there cars so therefore aren't really thinking about this, is my guess anyways
      11-01-2011, 06:06 AM   #13
ridin135
Best mod after a tune
      11-01-2011, 10:32 AM   #14
ModBargains IV
ModBargains IV's Avatar
Drives: e92 335i, 135i, E46 M3, 540i
Location: 1721 E. Lambert Rd. Unit C, La Habra, CA 90631
We've sold several of the AEM N54 Meth Kits since it's release and heard nothing but positive reviews from our customers. Here's one from our good buddy Kareem from NY:
Reviewer: Kareem A. From NY US
"The AEM Methanol Injection kit is very simple to install and Very easy to undeerstand all the error codes.This is a simple Mod that will give you alot more power. all in all I would give this Kit an A++"
Meth kit is a great addition to your mod list if you plan on running high boost setup or want to squeeze out more power from your current setup. Most people don't invest in meth kits because they simply don't need it (not planning to run high boost setups) and/or they do not want to deal with the installation which can take up to 6+ hours for most setups.
      05-16-2012, 03:55 PM   #15
entrepreneur177
из Кремля
Russian Federation
15
I wanna come back where it all started. Does anyone use Methanol injection now?
I'm sure it's awesome mod, but I still feel scared for my DCT....
      05-20-2012, 11:27 PM   #16
z4z4z4
z4z4z4's Avatar
Drives: 2002 M3
There are Z4s on the N54Tech forum that use it. Not sure if MT/DCT.
Most of the drag racing BMWs are using automatics, non-DCT, and transmissions are the weak link. Meth cars making nearly 4-500 wtq is a lot to ask the transmission to support. It shouldn't blow up, but expect eventual slippage at peak levels. Clutches will need replacement anyhow in time, so why not sooner and more often. The windshield washer bottle install takes less than an hour, plus drill/tap the stock charge pipe for the spray nozzle.....assuming you still have the JB4 installed to integrate the meth FSB.
Spend the $$$, enjoy the 500 whp for a little while then put it on the market for someone else to try.
I found this $2199 DCT 600whp clutch upgrade thread.
Sold 2011 Z4, kept 2002 M3
PM for various e89 parts 4sale.
      05-21-2012, 02:23 PM   #17
mrbmwz435i
Drives: z4 35i
this dynojet for a z4 35i ??
because i have now jb4 , afe filter stage 2 , downpipe , oilcooler , throtel spacer .. tomorrow or after tomorrow i will install the intercooler , blow valve and the methanol
      10-21-2014, 10:14 AM   #18
93Siro
Drives: Z4 35i
Bumping this thread. Anyone has ever installed meth kit in these cars? It's a trunk mounted setup so i need to do plumbing. What's the best route?
      10-21-2014, 07:43 PM   #19
Hujan
Hujan's Avatar
Probably under the car.
If I were going to do meth, it would probably be a trunk mount tank and pump, and I would think very seriously about using an Aquamist system that runs off duty cycle and boost, rather than just boost. I would probably run 70/30 meth to water, and I either wouldn't tune for it or, if I did run a tune specifically for it, I would only load one with a Cobb flash tuner and only on special occasions.
Also, if you are running meth, I don't see any reason not to use a DCI. The DCIs have the advantage of more air flow, but with the drawback that it is hotter air. But the combination of meth and a good FMIC will easily cool that air back down to ambient. In other words, you're leaving a lot of cooling capacity on the table by running a sealed CAI.
      10-22-2014, 02:01 AM   #20
93Siro
Drives: Z4 35i
I was thinking about running the line into the cabin and running along the door sill and going to the engine bay from behind the dash. I don't know if the later is a possibility though. Under the car sounds good. Need to check if i can find a route that protects the meth line from hitting to the ground.
As for the intake, i don't know. The DCI suck just the hot air around the engine and i strongly believe a FMIC can't cool it down enough. Meth surely helps cooling things down but i'm not planning to run meth all the time, atleast not aggressively. I might modify the stock ram air and come up with bigger inlets to increase the flow if the CAI doesn't give the turbos enough air. But that's for after building the DCT and running larger turbos.
BTW the oil cooler i got doesn't fit in the OEM position. I changed the plan and used it as a secondary oil cooler and placed it above the FMIC. Made a bracket and bolted it to the radiator frame. So no it's not a direct fit. It was a hard task though, had to run the lines both from drivers side because with hoses attached to the above and facing passenger side oil filter housing the hood wouldn't close.
      10-23-2014, 08:28 AM   #21
razorjimmy
Bang !
razorjimmy's Avatar
Drives: 2011 M3 ZCP Coupe
Thumbs down
I have BMS meth kit with AEM nozzle. Used WW tank as meth tank.
I don't think it is worth the benefit. You shouldn't use meth while tracking anyway. No point in daily driving either.
I tried 50/50, 70/30, and now using 100% meth. You get 1 extra psi of boost for all the hassle. You can only benefit (probably ~30hp max) from it if you make a rolling race, that's all.
Go for e85 fuel instead and a custom flash with proper fuel map that goes with it. You'll make way more power.
P.S. Meth in WW tank makes me psychologically uncomfortable.
2011 BMW E92 M3 ZCP - Jerez Black/Black/Carbon, Carbon roof, DCT, EDC, M Performance Exhaust
      12-23-2014, 08:20 AM   #22
Ramjet
Drives: z4 35i
Hey razorjimmy, can you post some details on your m3 oil cooler and m3 DCT cooler install - I'd like to do the same!
zpost
