06-10-2011, 05:39 PM | #1 |
Rep 14
Passenger side mirror is not in the same position.
This is just a irritating problem.
I dont know what makes the problem, but after I have made the settings I prefer via the electric adjustment system, the passenger side mirror seem to go back in the same position as before the adjustment. I always push and store the "memory-by the seat", when I adjust the mirror as I prefer, but it still go back. What seems to be the problem? May it be a small problem caused by my lack of IQ? Or might it be an error BMW have to deal with? best regards - jon from Norway
E92 M3 6TM + every option that is.
06-10-2011, 05:42 PM | #2 |
The Jesal
391
Rep 5,859
Does it do it regardless of which key fob you are using?
2009 E90 M3 - SOLD
06-10-2011, 05:44 PM | #4 |
Putcha ang ganda...
281
Rep 5,441
is your key inserted into the key hole or just on your pocket. assuming you have the comfort access.
06-10-2011, 05:46 PM | #5 |
Rep 14
I got 2 keys and I think the problem is with both keys. (The first key needed to change the battery, so I switched to hte other key. So, even thought the car is new for me, I have used both keys.
Hmm. Reprogramming the key? How to do that? THanks for the help, guys * I have the comfort a. It do that regardless if the key is in-car or in-pocket. * It does not change just after unlock (Im almost 98% sure), but It will change after a 10-60min drive)
