06-17-2011, 08:25 AM | #1 |
Rep 1,376
Drives: 1988 M3, 1990 M3, 1998 M3/4
Garage List 1998 BMW M3/4 [10.00]
2011 BMW M3 Sedan [9.28] 1988 BMW M3 [9.40] 1990 BMW M3 [10.00] 2008 BMW 135i - sold [0.00] 2003 BMW M3 - sold [0.00] |
AST 5300's on E90 M3
Before I get into details, I want to give a huge thanks to Harold@HPautowerks. I worked with Harold when putting together AST 5200's on my 135i and the results were just simply amazing on that car. Harold has been very easy to work with and customer service has been amazing! The 135i had all sorts of M3 parts on it so it allowed me to take the damper setup and put it on the M3. I decided to go ahead and convert to triple adjustable dampers before they went on the M3.
Link to 135i install: http://www.1addicts.com/forums/showt...light=ast+5200 I'm sitting here at a shop getting the alignment done right now so I will have a review of how it feels and everything when I have some experience under my belt with it. I'm still crossing my fingers that these LM-R's fit and that I didn't make a huge mistake on the wheels I bought. Basically, this is what was installed: Vorshlag Camber Plates AST 5300 Dampers with Remote Reservoirs Swift Springs and Thrust Sheets (504# front/784# rear - 7"/8") Swift Front/Rear Helper Springs Powergrid Anti-Roll Bar Links Rogue Engineering Rear Toe Links painted Porsche Guards Red Front of the car has been lowered: ????? (will update) Rear of the car has been lowered: ????? (will update) Front Camber: ????? Rear Camber: ????? Front Toe: ????? Rear Toe: ????? Caster: ????? Driver side canister Passenger side canister Rear Ride height and setup prior to alignment. I am definitely having height issues. I need the front as low as it is to look right, but the rear is a bit too high. I've tried searching for measurements but people aren't really documenting this. I will take measurements after a baseline is set so that others will have the info. Adjusting the rear height is a real pain as I didn't have a spanner wrench for the height adjuster and the whole thing wants to spin. I am going to look for a better solution for this as it was a frustrating battle to get it set where it is. Also, I don't know that it will allow me to raise the rear much more. Ultimately I will get the car cornerbalanced and that will really tell me whether or not these wheels were the way to go for me. Oh, the EDC module. I did the Macht Schnell EDC emulator and at the moment, I can't get it to work. I'll update on that as well.
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black 1998 BMW M3 - Alpine White/Mulberry 2011 BMW 328i racecar - LeMans Blue/Black |
06-17-2011, 04:29 PM | #2 |
Rep 3,832
I think your car sits nicely.
Im on KW Clubsports and my rears are too low, going to have to add a coil spacer to bring it up a little. My car is sitting at front 23 1/2" rear 22 3/4" from the lower rim edge to the fender. Im going to raise the rear 0.5" and the front 0.25".
06-17-2011, 04:46 PM | #3 | |
Rep 1,376
BTW, I'd love to see some of those RAC wheels in person. I had a set of RG4's on my Topaz Blue E46 M3. If I remember correctly, you were a fan of that combination What are your thoughts on caster? I'm thinking about moving it to the center like the stock configuration.
06-17-2011, 04:57 PM | #4 |
Moderator
675
Rep 4,737
Thanks for sharing Justin.
Just curious, have you always mounted the rear canisters on the toe arms? It might be safer to mount them on a non-moving part. I mounted my Moton Clubsport cannisters inside the rear trunk area through the vents. |
06-17-2011, 05:04 PM | #5 | |
Rep 1,376
I'd really appreciate any advice or input on how to do it differently. Thanks ridzhao for noticing that as I had forgotten to entertain any suggestions on their location.
06-17-2011, 10:13 PM | #6 | |
Rep 3,832
I think my shop left my caster close to stock, as I only have camber plates, no caster adjustment. Ya, I had a E46 M3 in Topaz....loved my RAC RS110s!!!!
06-17-2011, 10:21 PM | #7 | |
Supreme Allied Commander
3886
Rep 54,519
Drives: F80 M3
What size wheels and offset? Tire size? Harold |
06-17-2011, 10:33 PM | #8 |
Rep 1,376
Aggressive...
-20x9 ET8 - 245/30/20 Yokohama Advan Sport -20x10 ET18 - 275/30/20 Yokohama Advan Sport
06-17-2011, 10:39 PM | #9 |
3886
Rep 54,519
Drives: F80 M3
06-17-2011, 10:46 PM | #10 | |
Rep 1,376
Harold, I was going to try to raise the back up more but I'm out of adjuster room. I'll take some measurements but it makes me feel better that STALKER thinks it looks pretty close. I took notes on the stock ride height before I started so that I could compare. If I need to raise the rear, I either need to stack another radial thrust bearing in there somewhere or get different adjusters that are longer. I was in a pinch for time to get the height set for an alignment today and was having trouble raising the rear. I couldn't hold the threaded portion with my hand and turn the collar so I had to come up with a makeshift spanner wrench and hold the threaded collar with some channel locks. Result: raised it to the max position but did a good job of boogering up the adjusters I knew better..... On a different note, it sure does look good. Ran to a sandwich shop and to the gas station and got three comments on how good the car looked.
06-17-2011, 11:07 PM | #11 |
3886
Rep 54,519
Drives: F80 M3
I do agree on how great the car looks! Plus I really like white cars...all my cars are white.
Before adding another radial thrust bearing, make sure you have enough room on the collar to seat and locate the spring. |
06-17-2011, 11:13 PM | #12 | |
Moderator
675
Rep 4,737
For the rear spring, you can always add a spring spacer if needed, as Stalker and I have done. See picture below. http://www.m3post.com/forums/attachm...1&d=1306475213 Did you get a corner weight balance before alignment? |
06-18-2011, 06:01 PM | #13 | |
Rep 1,376
06-18-2011, 09:33 PM | #14 |
Moderator
675
Rep 4,737
I see. But definitely get corner balance before hitting the track. With higher rate springs, even if your adjusters are off by just a little bit, it can translate into quite a bit of corner weight difference.
06-18-2011, 09:46 PM | #15 |
Rep 1,376
I understand. I am actually sitting here surfing the web to see what it would cost to just buy a set of scales. Even looking at camber and toe gauges....maybe I don't need to take my car to an alignment shop anymore. The reality is that if I play with the height at all, I'm going to spend the money at shop to corner balance and then align the thing. Here in good 'ole Oklahoma, not having good luck with this.
06-19-2011, 12:14 AM | #16 |
Rep 9,034
So the coils don't allow enough ride height?
Isn't that the "Ericsson LM-R set-up?" It's very aggressive. Might as well learn to do the corner weight and alignment yourself if you can. That would allow trackside adjustments!!
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
06-20-2011, 05:26 AM | #17 |
Rep 5,264
Drives: 2008 E90M3
I love this suspension and can't wait to invest in it hopefully later this year =)
- Jason P
:Have: 08 E90M3, Varis VRS Front Lip, LS3, ESS Supercharger, Arqray Exhaust, Neez Wheels :Want: VRS Carbon GT Wing & Cooling Bonnet, LCI Taillights :Videos: EnvyRidesTV, GPR 1, GPR 2, GPR 3, ///MFEST |
06-20-2011, 04:35 PM | #18 |
Rep 697
Swift sells 9" springs which sounds like will fix your rear ride height issue. Strange how you are struggling with your rear adjustor. Mine spins freely with my bare hands when I loosen the pinch bolt. Maybe it's a snowbelt thing.
06-20-2011, 10:03 PM | #19 | |
Rep 1,376
I think my next investment is going to be scales and alignment tools. I'm growing tired of the lack of resources here in Oklahoma.
06-20-2011, 11:33 PM | #20 |
Rep 697
It looks like we've got different rear adjustors. Mine fit inside the stock cups and have a pinch bolt that you loosen up to rotate the collar. Like I mentioned, it's a very quick and easy operation for me. Not that that helps you now
Can't argue with alignment tools. I use my toe plates quite a bit but a set of smart strings would be even better. I've been balking at the price of the strings since the 90's. They would have paid for themselves by now if I bought them when they 1st caught my eye.. |
06-28-2011, 10:36 PM | #21 | |
Rep 1,376
23 1/16" front 22 7/8" rear left, 23" rear right I need different adjusters or a spring spacer to raise the rear more. Also, I raised the car up to unload the swaybar hoping that it would allow me to turn the adjusters easier....no dice. Not sure why I'm having such a hard time with this as it was easy on my 135i. I don't know if it is because the shock is so short or what. With the suspension completely unloaded in the back, my helper springs are almost fully compressed. The car looks great on the ZCP's, but I still love the LM-R's. Glad I did the ZCP to use as my winter setup (very mild here in Oklahoma). Any thoughts or suggestions would be greatly appreciated. I've PM'd a few people with LM-Rs to get height and alignment settings. So far only getting responses from an E92 so I still need some advice from the E90 crowd.
06-29-2011, 08:33 AM | #22 |
e36s54, e70x5d
151
Rep 1,723
Wtf?? Your running a 3-way Race Track Coilover with 500/700 lbs springs on a street car with 20" wheels and OE brakes?
You do know this is going to be a stiff street ride? Otherwise, great track kit .... AST makes some quality gear |
