06-19-2011, 04:25 PM | #1 |
Rep 204
I messed up..Help needed
I have recently purchased a 2011 BMW M3 in Mineral White pearl and after about a thousand miles i notice a small chip in the clear coat on my rear fender. Being anal i touched it up and was going to use the Langka product to flatten the blob. This did nothing at all. The blob remained and no matter what i tried i could not get it off. I would have left it alone if i knew this would have been the result. A friend suggested i use nail polish remover so in a last ditch effort i tried gently rubbing the remover on the blob. Not only did it remove the blob but it also left a yellowish looking tinge about the size of a silver dollar on my fender. Nothing i did could remove the yellow. is there anything i can try or is it time to head to the body shop. Your help is very appreciated.
06-19-2011, 04:36 PM | #5 |
Bimmerpost Resident Marijuana Consultant
457
Rep 3,197
Drives: 320i, 325xi, 335Xi, 335i, M3
Garage List 2010 BMW 335i [0.00]
2011 BMW X335i [0.00] 2006 BMW E90 325xi [0.00] 2011 BMW E90 335xi [4.00] 2011 BMW M3 E90 [7.00] 2006 E90 320i [0.00] |
thats like rubbing gasoline on your paint... I think your a bit screwed. Try some scratch X and see if it rids the yellow. Usually works on discolored paint, good luck. But I think this may be beyond scratch X
"AMG What! S-Line Who? If you ain't got that M I got no respect for you!" '06 Alpine Weiss E90 320i | '06 The Green Machine E90 325xi | '11 Alpine Weiss E90 M3 ZCP | '10 Silverstone X5M | '11 Alpine Weiss E90 335xi |
06-19-2011, 05:35 PM | #6 |
Rep 1,130
+1 on the scratch x or other abrasive. Nail polish (contains acetone) shouldnt harm cured paint. Perhaps the yellowing is caused by the clearcoat that you spread around while attempting to wipe it off. You can also try to clean the paint chemically, start off light with alcohol and then mineral spirits then acetone as a last resort (test first on an inconspicuous part of the car).
06-19-2011, 05:52 PM | #7 | |
Rep 243
JB, Bamboo, every option, 20" Adv.1
06-20-2011, 04:32 PM | #8 |
Rep 204
thanks everyone.....problem solved..brought the car to a high end body shop and they wet sanded the stain and the chip right out...also made an appointment for it to go back and have the whole car wet sanded to get rid of the orange peal and to have my wheels powder coated gloss black
06-20-2011, 04:35 PM | #9 | |
Rep 596
Glad you got it figured out. |
06-20-2011, 04:35 PM | #10 | |
457
Rep 3,197
06-20-2011, 04:48 PM | #11 |
Rep 204
they only charged $80 to get the stain and chip out and they are wet sanding and polishing the entire car for $350 so its really not to bad...their work it out of this world as well...they are a factory authorized Lambo, Ferrari, and Aston Martin repair center...and as for complaining about the orange peel this is my 3rd M3 and right before it i had a 2010 Audi S5...all german cars are the same deal....its a way of life...
06-20-2011, 06:57 PM | #13 | |
that's what SHE said!
75
Rep 1,163
06-20-2011, 08:37 PM | #14 |
Rep 204
The owner and I ended up having a mutual friend so he's helping out with the pricing. He was very reasonable on the wet sand but a little higher then most for the wheels..so it all evens out in the end
06-21-2011, 09:16 PM | #16 |
Rep 113
I luv them! Will orange looks good on this wheels too?
2004 W209 CLK55 AMG BLK SOLD
2010 E92 ///M3 WHITE 1. RPI GT Exhaust 2. Gloss Black Akrym Lip 3. Eibach Pro Kit 4. 20% Tinted all around 5. CF side markers 6. Matte black front grills 7. CF Hood Vents. 8. CF OEM Spoiler |
06-22-2011, 08:53 AM | #17 |
Lurker
78
Rep 812
Success!
Next time, don't try to use household crap on your car. I think Langka needs to be used within a certain time of applying the touchup. If it's been too long, go to compound followed by swirl mark remover and finally a normal polish. You can save some time with some very fine sandpaper (like 1600 grit) but be careful to only work the blob. And finally, don't bother with the brush that came with the touchup paint. Use a round, sharp toothpick to drop the touchup paint exactly into the chip. Use multiple coats if needed to slowly build it up and avoid the blob.
