04-05-2007, 12:49 PM | #2 |
Rep 8
whait there is more
Specifications BMW M3 Coupé. Body M3 Coupé No of doors/seats 2/4 Length/width/height (unladen) mm 4,615/1,817/1,418 Wheelbase mm 2,761 Track, front/rear mm 1,538/1,539 Turning circle m 11.7 Fuel tank approx ltr 63 Cooling system incl heater ltr 11.4 Engine oil ltr 8.8 Transmission fluid ltr 2.1 Final drive fluid ltr 1.2 Weight, unladen, to EU1 kg 1,655 Max load to DIN kg 500 Max permissible weight to DIN kg 2,080 Max axle load, front/rear kg 1,020/1,120 Max trailer load2 – braked (12%)/unbraked kg – Max roofload/trailer download kg 75/– Luggage compartment to DIN ltr 400 Air drag Cd x A 0.684 Engine Config/No of cyls/valves V/8/4 Engine management MS S60 Capacity cc 3,999 Bore/stroke mm 92.0/75.2 Compression ratio : 1 12.0 : 1 Fuel grade RON 98 (95) Max output kW/hp 309/420 at rpm 8,300 Max torque Nm/lb-ft 400/295 at rpm 3,900 Electrical System Battery/installation Ah/– 70/luggage compartment Alternator A/W 180/2,520 Chassis and Suspension Suspension, front Aluminium two-joint spring strut axle with tiebar; small, positive compensation of transverse forces; reduction of brake dive Suspension, rear Five-arm axle with anti-squat and anti-dive Brakes, front Single-piston swing-calliper compound disc brakes Diameter mm 360 x 30, vented and cross-drilled Brakes, rear Single-piston swing-calliper compound disc brakes Diameter mm 350 x 24, vented and cross-drilled Driving stability systems ABS, ASC, CBC, DSC; variable M differential lock Steering Rack-and-pinion steering with hydraulic assistance and Servotronic Steering ratio, overall : 1 12.5 Type of transmission SG 6 Gear ratios I : 1 4.055 II : 1 2.369 III : 1 1.582 IV : 1 1.192 V : 1 1.000 VI : 1 0.872 VII : 1 – R : 1 3.678 Final drive ratio : 1 3.846 Tyres, front/rear Rims, front/rear Performance Power-to-weight ratio to DIN kg/kW Output per litre kW/hp Acceleration 0–100 km/h sec standing-start km sec In 4th gear 80–120 km/h sec Top speed km/h Fuel Consumption in EU Cycle Urban ltr/100 km Extra-urban ltr/100 km Composite ltr/100 km CO2 g/km Miscellaneous Emission standard Weight of car in road trim (DIN) plus 75 kg for driver and luggage. 2May be increased under certain conditions. 3Electronically limited. |
04-05-2007, 01:41 PM | #4 |
Reincarnated
245
Rep 4,227
All pics are already in the right forum, the Photo/Video/Medi Gallery".
04-05-2007, 08:16 PM | #6 |
//Mdicted
348
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
and heres what all been waiting for
the impressive tq chart
04-05-2007, 09:03 PM | #7 |
Reincarnated
245
Rep 4,227
The torque chart has been out since the engine specs were released. Where have you all been??
04-05-2007, 09:13 PM | #9 | |
//Mdicted
348
Rep 9,988
My sincere apologize if I have cause folks harm, pls forgive me
04-05-2007, 09:17 PM | #10 | |
Reincarnated
245
Rep 4,227
My next priority has been scanning a couple forums religously for the smallest details
04-05-2007, 09:19 PM | #12 |
//Mdicted
348
Rep 9,988
I understand....
