07-08-2011, 07:48 PM | #1 |
Rep 2,940
Front fender gap on 2011 M3 ZCP seems excessive
So I've had my 2011 M3 with ZCP for just over a week now. Love it. I am surprised at how much front fender gap I have stock, however. Front fender height is 27.5" and rear is 27". Is this normal? If not, what could be causing this? Does the front settle over time?
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner Last edited by LarThaL; 07-08-2011 at 08:08 PM.. |
07-08-2011, 07:51 PM | #2 |
Rep 1,488
Drives: 2012 e92 M3 DCT ZCP
I don't own a m3, but have seen several threads where shipping blocks were not removed upon delivery. Check, otherwise I suppose it's normal.
07-08-2011, 07:52 PM | #3 |
Rep 6,149
I had to re-adjust mine when I got it 2 weeks ago. Send pics so I can see if you have the same issue that I had. Then I can try and help you if it was the same.
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
07-08-2011, 07:57 PM | #5 |
Rep 1,636
07-08-2011, 08:21 PM | #6 | |
Rep 2,940
Here are pics: [IMG][/IMG] As you can see....no shipping blocks. This is the first thing I checked. [IMG][/IMG] I can fit three of my smallish fingers in between the front tire and fender. In the rear I can't even get two fingers in. Is this normal for the front?
--Former BMW M3 owner Last edited by LarThaL; 07-08-2011 at 08:40 PM.. |
07-08-2011, 08:43 PM | #7 |
Rep 2,940
No shipping blocks....unless I am really blind or just not looking in the right place. Springs are free and clear. I was wondering more if the shocks were somehow "closed up" or something given that I have EDC, or do EDC cars sit higher by a small amount?
--Former BMW M3 owner |
07-09-2011, 06:14 AM | #8 |
Rep 525
Drives: '21 F95 X5 M C, '11.5 E92 M3 C
Sorry I can't help but that looks like a fairly big gap. Mine is no where that high. From the pics it doesn't appear to have the shipping blocks either.
Drives: '11.5 Interlagos Blue E92 M3 Comp, '21 F95 X5 M Comp DIYs: Enable Rear Fog | Easy Side Gill Replacement | Front Grill Replacement |
07-09-2011, 06:23 AM | #9 |
Rep 525
I just checked mine and it's about 3/4 inch less then yours.
A suggestion is to check your tire pressure. I remember when I came home with my car it had over 50psi of pressure!!! The dealer forgot to lower the pressure!!! I believe from the factory they usually pump it up to give the car more ground clearance during shipping. Check yours, probably same situation.
07-09-2011, 06:31 AM | #10 |
Rep 5,678
The gap does look larger than it should on a ZCP car. My gap is 1.25" from the top of the tire to the fender. I can just get two fingers in there. The rear gap is even smaller (although I also have 275/35 tires on the rear so that would make the gap a little less than with 265/35 tires).
Your gap looks to be much larger than 1.25". That gap looks as big or bigger than a non-ZCP car. The gap on my 2011 ZCP didn't seem to change much since delivery either... that is, it didn't appreciably settle any lower or, if it did, it wasn't enough to notice. I would take the car to the dealer and compare it with another ZCP on the lot. If there is a meaningful difference, have them investigate. I expect it will be difficult to get them to do much as they will give you the "it's normal" answer.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 Last edited by gthal; 07-09-2011 at 06:42 AM.. |
07-09-2011, 06:34 AM | #11 | |
Rep 5,678
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
07-09-2011, 06:36 AM | #12 |
Rep 5,678
I think he misread your post as if you had a gap between body panels that was too large and needed adjusting.
07-09-2011, 06:45 AM | #13 |
Rep 13,018
That gap is excessive for a ZCP. A friend just got his brand new E90 M3 with ZCP this week after ED and I can say that his car front gap is about 75% less than yours.
Try driving it for a few weeks to see if the springs settle a little bit. But I doubt that it will be the inch or so that is required to be "normal". |
07-09-2011, 07:02 AM | #14 |
Rep 5,678
Yours...
Mine... front... Mine... rear... To me, there is a HUGE difference in fender gap on your front compared to mine. Notice how little of the suspension you can actually see on mine. I would definitely take this to the dealer and, at the very least, show them these pictures (unless they have a ZCP on the lot). |
07-09-2011, 08:39 AM | #16 |
collecting toys
41
Rep 810
Maybe you have the rare M3Xi which is raised for snow clearance.
I also looked at mine and yours is higher.
2011 e92 M3 Monte Carlo Blue ESS 535 - gone but not forgotten
2015 cayman GTS - new toy 2006 SLK 55 AMG sold |
07-09-2011, 09:18 AM | #18 |
the original brown guy
116
Rep 1,011
Drives: '22 MBB/SO X5M Comp
That is definitely a bit excessive....almost the same size as my normal M3
PREVIOUS
2019 G05 X5 M50 AG/BLK 2017 F15 X5 5.0 M Sport AW/BLK 2011 E90 ///M3 AW/FR 2008 E92 ///M3 IB/BLK |
07-09-2011, 12:24 PM | #20 |
Rep 5,678
I would say it is higher than a non-ZCP M3 too... the non-ZCP is only 10mm higher but the OPs car is much higher than 10mm.
07-09-2011, 01:34 PM | #22 |
Rep 3,153
Are you sure you dont still have the shipping blocks in your suspension? I have seem some posters on here that brought their car home with the shipping blocks still in it because the dealer forgot to remove them. Thats what it looks like to me.
2011/E92/M3/MR/BB/ZCV/ZP2/EDC/2MT
