      07-13-2011, 02:19 PM   #1
M3Power79
Belgium
31
Drives: 1M sold - M4 MW DKG ordered
H&R Lowering springs installed! VA -30mm RA -15mm
Just installed
First impressions are good. Not really more uncomfortable then it is stock. First i was afraid that it would become more bumpy but it isn't. Roads in Belgium are a disaster so this was not an option. Bodyroll is on public roads almost not noticable, a closed circuit will be a better place to push the suspension to the limit
Looks have IMPROVED significant!!!!
Bye bye fist wheelgap at the front
Some pictures :
"... on the smiles-per-mile charts, the 1-series M coupe can't be beat. It is a challenging piece, a triple-X-rated driver's machine for semi-professionals. Its handling balance provides an open invitation to indulge in latent oversteer, and provides an opportunity to separate the men from the boys. It is an absolute hoot on the track and an addictive plaything on your favorite twisty back road. "
      07-13-2011, 02:25 PM   #2
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Perfect! Are these the M3 H&R springs?
      07-13-2011, 02:29 PM   #3
M3Power79
Belgium
31
Nope : 1M Springs ( check the number on the spring )
http://www.h-r.com/de/n_produkt.php?id=1973
      07-13-2011, 02:40 PM   #4
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Thanks.
      07-13-2011, 04:04 PM   #5
nicoz
Drives: 1M
Hi,
How much and how did you ordered them?
Thanks
      07-13-2011, 04:28 PM   #6
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Nice. I might just do the fronts only.
      07-13-2011, 04:33 PM   #7
M3Power79
Belgium
31
Originally Posted by nicoz View Post
Hi,
Thanks
They cost 397 € and i've ordered them here in Belgium by the H&R importer
      07-13-2011, 04:39 PM   #8
M3Power79
Belgium
31
I would not do that because the car would lower 30mm at the front only and will lean to much forward. The balance will be disturbed and understeer will show up. The H&R springs are also stiffer so that would complety disturb the car. In this picture you'll see what i mean :
      07-13-2011, 04:42 PM   #9
elitt13
elitt13's Avatar
France
156
Drives: 1///M Coupe & ///M2 CS DKG
2020 BMW M2 CS  [0.00]
2011 BMW 1M coupé  [10.00]
2007 335i  [0.00]
nice!!!
- Série 1 ///M BSM -
      07-13-2011, 05:04 PM   #10
1SerieStud
1SerieStud's Avatar
184
Drives: '11 VO 1M (498 of 740)
You already disturbed the car by changing the geometry of the M suspension - which is one of the best things this car has to offer. Let alone that the stock struts/shocks were not designed to work with H&R springs.
      07-13-2011, 05:26 PM   #11
Dan Parker
Drives: 2012 Golf R
Looks better. Performs worse.
Dan Parker
      07-14-2011, 12:20 AM   #12
mPlasticDesign
684
this
I have no plans to do any serious tracking like Dan. The back stance is perfect, wouldn't mind if the front was 3/4-1.0" lower for appearance. Seems like such a modest drop would have little affect on the OE dampners or performance. My M3 did not have EDC, so I went with the Dinan Stage I setup and it seems to put it at a similar feel to the 'sport' setting on the EDC. It also increased travel rather than reducing it like most springs do. Maybe I'll wait and see what Steve comes up with for this car or if it can be used straight across between models.
      07-14-2011, 03:06 AM   #13
M3Power79
Belgium
31
It doens't feel so. It feels more planted on high speed. My former E36 M3 3.2 was also lowered with just springs from Eibach on dampers from Bilstein (B8). This wasn't a kit also but they worked fine together.
I'll fly over to the Dragons tail to show you
      07-14-2011, 03:27 AM   #14
gazz
///Mbassador
gazz's Avatar
Australia
26
Drives: The horse I fell off
Bye bye front wheel gap - hello front bumper scrapes.
      07-14-2011, 05:31 AM   #15
Mistercup
Mistercup's Avatar
Belgium
Drives: E82 BMW 120 D Coupe
2009 E82 120D  [0.00]
Really magnificent with the belittlement. Just what missed him(her).
It seems to me that there is already some 1 Mr Mais I have no again seen it: (
We never know, if you know not. I am a member of the bmw-one.com forum Belgian Forum BMW
      07-14-2011, 06:06 AM   #16
Grey Dove
Grey Dove's Avatar
Drives: Sold for a reptile
30mm lower in front??? that's a lot. I must say it looks way way better
      07-14-2011, 07:23 AM   #17
bmw13
bmw13's Avatar
Drives: 1M - GIAC:S2
Why are people so eager to change out the high quality M parts that we get stock for aftermarket parts?!? BMW's M engineers know what they are doing and I am sure they had it like this for a reason!! Obviously for performance purposes, and something like that, I would not mess with, but to each their own.
Follow my car/ life via Instagram @rdauito
2011 E82 1M #215 of 740
http://www.1addicts.com/forums/showthread.php?t=877009
      07-14-2011, 08:47 AM   #18
Dan Parker
Drives: 2012 Golf R
Did the alignment work out to get it back to factory specs (or close)? I'm changing my suspension out for Motons in 2 weeks and wonder if I'll need adjustable bits.
Dan Parker
      07-14-2011, 09:01 AM   #19
M3Power79
Belgium
31
The alignment worked out to be quite simple and fits in the factory specs perfecly. Their is a big tolerance in most values to align the car the way you want to drive it. I choose for a more track oriented aproach with enough negative wheelflight for example.
      07-14-2011, 09:06 AM   #20
M3Power79
Belgium
31
Here in Belgium we hava bumps to slow down traffic everywhere and the not steep ones i can take as i did before. Not met a steep one till now
I'll be carefull, that's for sure. But i always do, lowered or not
      07-14-2011, 09:11 AM   #21
Franklin Joseph
What other adjustable bits are available? My suspension should be installed in a couple weeks (hopefully) and will align/corner balance then.
      07-14-2011, 10:32 AM   #22
MDORPHN
Drives: AW 1M
Camber/caster plates.
Neil
1addicts
