      07-22-2011, 07:18 AM   #1
romak47
romak47's Avatar
Drives: like a bat out of hell
helix fmic tips tricks?
Hey,
For anyone that has put in a Helix FMIC for the 135 can you let me know any pointers you may have? Gonna install mine this weekend so just wanting a smooth hassle free install.
Is it easiest to put the couplings on the car side ducting first or the IC side? Is it recommended to lube the couplings? stuff like that..
thanks.
JB4, DCI, Digi boost, CSL eyelids, 5% tint, KW v2's. Bastuck 85mm quad w/ berk resonated mids, LED int ltg, Perf SSK, CF int trim, 19" SF-71 rims, CDV mod, BMS OCC, ER+tial charge pipe. AR DP's, Helix IC,meth, drilled slotted rotors
      07-23-2011, 07:53 AM   #2
romak47
romak47's Avatar
no replies :*(...
Fine then! ima go break my car then ! lol
      08-15-2011, 02:58 AM   #3
BadOneThreeFive
BadOneThreeFive's Avatar
Guam
60
Drives: 2008 BMW 135i
Well since you have installed the helix FMIC mind giving me some pointers? lol i got mine coming in soon.
08 135i N54
- Vargas Stage 1 Turbos with Billet wheels
- BMS Intake, BMS Charge pipe, AR DPs, Stock mids, berk race muffler delete
- JB4 G5 Map 3 75 Meth Additive with RACE DME flash
- MS-109 and 100% meth injection (Single CM12 nozzle)
      08-15-2011, 06:13 AM   #4
romak47
romak47's Avatar
http://www.1addicts.com/forums/showthread.php?t=563071
thats my DIY... all else you need is in the vids helix has..
      08-17-2011, 08:01 AM   #5
seslait
Drives: 135I
Great DIY. Can't wait to get my Helix!
      08-17-2011, 03:52 PM   #6
romak47
romak47's Avatar
youll love it, HUGE improvement over stock IC.. Solid IAT, and more boost when using map 5 on JB4.. I got 2psi increase after install..
      08-18-2011, 06:52 AM   #7
seslait
Drives: 135I
I'm running map 2 on the jb4. should I switch once I install the FMIC. Or will map 2 still be the more aggressive one?
      08-18-2011, 04:34 PM   #8
romak47
romak47's Avatar
map 5 is autotune.. and 11-16 psi dependent on mods you got.
I still have my downpipe cats and able to do 15-16 psi
map 2 requires no downpipes and maxes out at 14.5 psi..
im sure youd see more boost at map 5 if you have helix FMIC and kityless downpipe
      08-18-2011, 07:28 PM   #9
seslait
Drives: 135I
Thanks. Yea I have MS DPs and full sport berk exhaust so I should feel it then.
1addicts
