08-05-2011, 03:26 PM | #1 |
Rep 45
Drive mode
Hi Guys,
Just a quick question, when the DCT is on drive mode it always preset to D2. Is there a way to chage it?. This is standerd settings when driving on normal conditions. Cheers, |
08-05-2011, 03:42 PM | #3 |
Rep 226
My '08 seems to default to the last setting and always comes up on 5 in Drive. Yours probably does the same. The manual mode seems to always come up on 2 (I believe) and you have to use the rocker selection to get to 5.
08-05-2011, 03:44 PM | #4 |
Rep 45
Yes I can adjust it using the button below the gear shifter. But the settings only last till the ignition on. Once engine turn off and turn on it goes back to D2 again.
Is there a way to set the default to something else other than D2? |
08-05-2011, 03:57 PM | #5 |
drop a gear and...
79
Rep 967
When you are on the screen to configure your M-Mode settings - Press the options button and have a look. I ran across this while driving so I didn't mess with it but it might be what you're looking for.
08-05-2011, 06:39 PM | #7 |
drop a gear and...
79
Rep 967
Yeah I checked on my way home - Fail.. Sorry.
08-05-2011, 06:45 PM | #8 | |
Rep 1,432
US-spec M3's default to S3, Euro-spec M3's default to D2. Cheers |
08-05-2011, 07:52 PM | #9 |
Rep 154
Next time when you are driving in D2, use the little rocker below the shifter to change to D3, D4 or D5 (indicated by the number of bars in your dash). Arrive at your destination and shut off the car as usual. Now when you start it again next time and put it in D, it will remain in whatever mode you left it in.
2018 X3 M40i Phytonic Blue / Cognac
Retired: 2009 E93 M3 Space Gray / Fox Red Extended |
08-05-2011, 08:55 PM | #11 |
Rep 1,848
pman10 has it right. The OP has different defaults then what the US cars have. So everyone from the US that replies will think "what's wrong this guy since mine D mode remembers my last setting?"
08-05-2011, 09:05 PM | #12 |
drop a gear and...
79
Rep 967
Can the default be changed by coding?
08-05-2011, 09:05 PM | #13 |
Rep 264
I don't know but it seems like a lot of energy is being used to make D mmode default to a setting to other than factory specs. I usually select several other options when I start, such as upping the EDC to prevent bottoming out at the end of my driveway. Actually, I almost never use D mode, that's for my wife.
08-07-2011, 10:06 PM | #14 | |
Rep 1,432
Also, you can preset your start-up EDC (and I believe throttle setting) in the M-key settings menu. |
