09-03-2011, 09:53 AM | #1 |
Rep 5,018
Drives: VALNCYA
FS: Procede V5 1M Specific
PROCEDE!
ASKING 800.00! 't believe that there should be any such thing as a "low-end" tune. Either a tuning device should control the engine properly or it should not be released. Even the lowest priced tunes must not sacrifice performance, drivability or engine safety in favor of a low price point. In terms of performance and functionality, our Procede Rev3 will outperform any other tuning options. Whether you BMW is otherwise stock or fully modified, you can rest assured that the Procede will satisfy all your current and future needs. $945 PROcede Rev2 V2.5 Includes MSRP! - Includes USB Comms cord - User manual - Harness PRO VERSION! Plug and Play (PnP) Harness AutoTuning Vishnu Command Center Closed-Loop Ignition Timing Control Flat-Foot Shift/No-Lift Shift (6MT) 2-Step Rev Limit/Launch Control (6MT) Built-in PWM Methanol Control I/O Built-in Methanol Pump Arming Circuit 3bar MAP sensor input External 0-5v wideband input Automatic Wastegate Compensation In-Dash Multi-Informational Displays On-the-fly Mapswitching DME code reading/clearing Built-in Wideband AFR Monitoring High-Speed Datalogging In-Dash Trouble Code Display Isolated PID Boost Control Speed Delimiter Diagnostic Invisibility Adjustable/Audible Shift Alert Diagnostic Adaptation Resets Wastegate Rattle Fix Performance Traction Control Secondary Autotuning Map (Map2) Naturally Aspirated Map (Map3) Progressive Methanol Map (Map4) Complete map-ability though User Tuning Interface USB interface (cable included) Last edited by MusclezMarinara; 10-18-2011 at 10:45 AM.. |
09-03-2011, 10:31 AM | #3 | |
Rep 4,190
What parameters were changed for the 1M map? |
09-03-2011, 10:51 AM | #5 |
Rep 5,018
Drives: VALNCYA
09-03-2011, 12:33 PM | #6 |
Rep 475
Drives: 1///M Coupe & ///M2 CS DKG
I don't understand?? you put the V5 on the 1///M or not?
do you have the map from shiv or some log of the procede on the 1///M?
- Série 1 ///M BSM - |
09-04-2011, 08:09 AM | #7 |
Rep 5,018
Drives: VALNCYA
im trying to see what you guys think I have not installed it yet and its fully re programmed from shiv and his team...its not in the car yet as I'm not sure if i want to keep it, it will VIN lock.
09-04-2011, 08:44 AM | #10 |
European Editor
10628
Rep 22,992
I thought you were trying to sell your 1M for $90K on ebay. ???
I would keep it stock unless you wil be keeping your 1M. Maybe the used car 1M market has bottomed out. ? |
09-04-2011, 10:20 AM | #11 |
Rep 3,939
+1, specially for the premium you're asking, even though I personally wouldn't buy it for MSRP or lower if I knew it had a product such as Procede installed at any point in time.
10-18-2011, 10:46 AM | #13 |
Rep 5,018
Drives: VALNCYA
BUMOP!
10-18-2011, 11:27 AM | #14 |
Rep 965
wait, are you reviving this thread? so what is it...are you trying to sell again or just looking for opinions? (sorry if it sounds harsh...I'm not trying to be).
10-18-2011, 11:55 AM | #15 |
Rep 971
Drives: Ducati Hypermotard
Mods should move this to the FS section.
BMWCCA #454364
10-18-2011, 11:33 PM | #16 |
Rep 5,018
Drives: VALNCYA
10-19-2011, 03:20 AM | #17 |
Rep 971
Not entirely true, which is why they moved simple_simon's "1M For Sale" post to that section. It's a 1addicts "For Sale" section, not just specific to 128 or 135.
BMWCCA #454364
10-19-2011, 08:30 AM | #18 |
Rep 965
sorry, i agree with mike. it's a 1addicts forums still...i look on the FS stuff all of the time. a lot of various things can be shared between the two. and then there' always ebay.
