09-05-2011, 12:56 AM | #1 |
Supreme Allied Commander
3886
Rep 54,510
Drives: F80 M3
TCKline Bullet Head Pro-Racing 135i 1M Wheel Studs
TCKline Racing with their Nascar Style bullet-shaped radius pro studs that all but eliminates cross threading. The TCKline Racing pro studs are made from degassed, tumble blasted 4140 aircraft steel and coated with baked on dry film lubricant to reduce the possibility of galling and ensure consistent clamp loads.
Fits ALL late model BMW's. TCKline Racing pro studs are available in 3 different lengths: Long DIMENSIONS: Overall Length = 100 mm Threaded area from the hub = 60 mm Total length from hub to tip = 74 mm Accepts up to 25mm spacer Medium DIMENSIONS: Overall Length = 90 mm Threaded area from the hub = 51 mm Total length from hub to tip = 65 mm Accepts up to 15mm spacer Short DIMENSIONS: Overall Length = 81 mm Threaded area from the hub = 42 mm Total length from hub to tip = 57 mm Accepts up to 8mm spacer Lug nuts are available in cad plated steel or black coated steel. Studs $9.50 each Nuts $1.95 each Order here: http://www.hpashop.com/product.sc?pr...categoryId=256 |
09-21-2012, 03:35 PM | #3 |
teh porcupine
98
Rep 1,726
Drives: 2020 Tesla 3 LR AWD
The website shows a chrome nut with no option for black?
10-02-2012, 12:20 AM | #4 |
3886
Rep 54,510
Drives: F80 M3
