09-26-2011, 01:10 AM | #1 |
Rep 954
BMW Performance Parts Install, Observations
Installed the following "Performance" parts today and would like to share some of my observations:
- Painted reflectors. Piece of cake. Use a towel and something wide and flat to push/pry from the bottom - Kidney Grills. Used a DIY published here. As many pointed out, the worst clip is the one closest to the headlight, I concur. But do not do it first. Undo the 3 on top then it is a lot easier to deal with the "headlight" clip. - Side gills. Piece of cake. I used the scotch tape method published here. Just apply some scotch tape to give yourself leverage and wiggle the hell out of it. If you're using anything but your hands (god forbid - screw driver!) - you're doing it wrong. - Key hole delete. It took me a while to figure out that the access hole to remove the screw is under the door trim (I have a coupe). I felt kinda stupid after looking at the DIY video published here and not being able to locate a plug featured in the video.. - CF Mirror Caps. Piece of cake. Just pull and wiggle. Comes off like a charm. No tools needed. - CF Spoiler. This one was a bit complicated compared to everything else. I used a DIY published here. You will definitely need a heat gun to do this job. Removing the OEM spoiler was easy, I used a fishing line and a heat gun. But removing glue residue was a bitch. I had stuff called Guff Off from Lowes. It works good as long as there is little glue left. The only problem is that after removing the spoiler there is sh%t load of glue left. I found solution - scrape off some glue and form a glue ball, then use your heat gun to heat the glue on the trunk (inch at a time) and use the glue ball to remove just heated glue. It is a painstaking process and my fingers still hurt, but it works. The glue ball will grow larger Then use the solvent to remove the traces. Second part was to apply Betalink. Use it sparingly, I used little, but still I think I could have used less. My mistake was that I did not mark the exact location where I want to install the spoiler. After moving it a little to position it where it needs to be I ended up with a bunch of Betalink around the spoiler. This stuff is not fun to clean up. Use AS LITTLE AS possible in the center section looking at it from the rear. That gap is the hardest to clean. And have your blue painters tape handy, you will need it to secure the CF spoiler in place. I also did CF licence plate frame and M3 valve stem caps. I am done for now Saving money on exhaust |
09-26-2011, 08:48 AM | #2 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Thanks for the tips!
09-28-2011, 04:39 PM | #3 |
Rep 227
I agree with you on the Performance CF Spoiler install. The center section from the rear was a real pain to clean up (especially since I was working around the tape used to secure the spoiler) and there is still a tiny bit of Betalink visible if you look closely. So to all of you DIYers out there, use Betalink sparingly!
I have had the spoiler on for roughly a month now and I have to say that it is holding up great. Solid as a rock. I do not take my car through automatic car washes so I cannot comment on how it holds up in there (I have always wondered but auto washes are a big no-no for me) OP: you have a great "first round" of mods on your car. Enjoy and thanks for your comments! |
10-10-2011, 07:44 PM | #4 |
Mpbruin108
187
Rep 854
For some reason, when I called the dealership in Monrovia, CA, which I heard is pure crap but hey, i Just wanted some glue, they tell me that BMW only use strips of adhesive and no betalink. I gave him the part number of the betalink I found on the forums and he said it was the same one? I'm so confused, this betalink stuff aren't strips of tape right? I figure that is what 3M tape is for. He wanted to charge me 25 bucks for strips of tape...absurd!
So Cal Drivers: Get your Tires from us to get them QUICKLY (same or next day) and at a GREAT Deal.
2244 Tyler Avenue, South El Monte| Call: 626-443-8539 Active: 2015 BMW i8, 2024 BMW iX, 2018 Mclaren 720s |
10-11-2011, 01:08 AM | #5 | |
Rep 954
10-18-2011, 03:05 PM | #6 |
Rep 1,883
Drives: 2011 E92 M3
I used Betalink on my diffuser. Bought that from a dealership. The tape that came with it didn't hold very well, so decided to go stronger. Be prepared, the betalink will get all over the place. Wear latex gloves, and be ready to use the solution.
As for the CF spoiler, I installed mine with 3M double sided tape. You don't need the betalink. If you track a lot, it may or may not come off, but I doubt it. The OEM lip was installed with tape too if you notice that when you remove it. I also didn't use a heat gun. I used 3M adhesive remover, fishing line, and some elbow grease. It worked like a charm. The heat gun might have made it come off a little easier, but there's a greater chance of damage to your paint if you're not very careful. I decided the risk wasn't worth it and got the spray adhesive remover. No issues here...
'11 BMW E92 ///M3 - ZCP and DCT
'15 Ford F-250 - Lariat, 6.7 Powerstroke Turbo-diesel |
10-23-2011, 10:21 PM | #7 | |
Zoom Zoom This
12
Rep 694
You may not even notice if you eat 90% of the clear off of it until that first buffing. |
11-08-2011, 11:15 PM | #8 | |
Rep 1,489
11-09-2011, 10:23 PM | #9 |
Rep 954
I do not have splitters. Here are some shots of my minor mods
11-10-2011, 01:57 AM | #10 |
Rep 1,489
Looks very good! Sharp!
I was undecided on the rear spoiler, but I am now going for it. I wonder how it would look painted white? Just thinking. |
11-10-2011, 03:00 PM | #11 | |
Rep 954
I think painted white it will look great, but I really love the way black and white compliment each other in my car. White body and black grills, mirror caps, spoiler, roof, wheels, tint etc.. to me this is what creates the great look. Sometimes, when I see a black car with everything black on it from wheels to the M3 logo on the trunk, to me it looses part of the beauty. The same holds true for other colors. There has to be a contrast to see the form! IMHO |
11-19-2011, 07:17 AM | #12 | |
///M 5light
248
Rep 439
13 MCB ///M5
11 - 12 MW E92 ///M3 ZCP 08 - 11 E90 335i |
11-19-2011, 07:19 AM | #13 | |
///M 5light
248
Rep 439
13 MCB ///M5
11-19-2011, 09:41 AM | #14 |
10837
Rep 27,614
looks great, good job. Its always more satisfying when you can say you did it yourself
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
11-19-2011, 11:58 PM | #15 | |
Rep 954
Did you have it installed at a BMW dealership? I cant believe that they f$&ed it up. |
11-20-2011, 12:01 AM | #16 |
Rep 954
