10-09-2011, 02:10 AM | #1 |
Rep 213
380mm Stoptech Trophy and Stock 18's....
After a couple track sessions running over heated stock brakes I figured it was time for an upgrade. After some careful measurements I decided to go with the Stoptech Trophy 380mm kit. What a nice kit and instructions were great. I won't go into the install as there are a few other post detailing how to do it. One post in particular where I would really have to thank for the good tips is this one. Post. It was really helpful and I would definitely recommend anyone getting ready to do this upgrade yourself to read up first as it really helps. Actually one tip I thought was really invaluable was item number 2. in the post. I was a little skeptical at first and expected some brake fluid to be spilled when I disconnect the lines but having the brake pedal depressed and locked at about the halfway mark really works. Hardly any fluid came out after disconnecting the lines. For others looking to do this I took a pic of how I kept the brake pedal depressed using a 2 foot level and wedging it between the pedal itself and the front of the seat. Worked perfectly. Other than that I was sooooo glad the 380mm kit fit the stock 18's. It’s a tight fit but there is still a good amount of clearance. What specifically made it fit was having a 15mm spacer. Without the spacer there would be some interference. Here are some pics from my install.
10-09-2011, 05:13 PM | #4 |
Rep 454
Good looking brakes! I didn't think they fit the 18s... I just ordered the 4 piston setup for that reason. But props for working it out!
Ride: 2020 F87 M2C, 6MT Drive: Nine-Four Motorsports
Before: 2013 - 3.8L GTR, first DCT 2012 - 5.2L R8 v10, 6MT 2011 - 4.0L E92 M3, 6MT |
10-09-2011, 06:02 PM | #5 |
chris
278
Rep 12,144
wow the clearance looks incredibly tight ! i cant believe it fits the oem 18" wheel!! incredible.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
10-09-2011, 07:08 PM | #6 |
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
Your going to love'm, great choice.
My detailer used something on my car that hazed the anodizing, very upsetting, be sure to use only mild cleaning products and wash it off immediately. I might paint the calipers now.
F80 M3 / Mineral Grey-Silverstone / CCB
10-09-2011, 10:56 PM | #7 |
Rep 8,077
Drives: 11 E90 M3 Individual
Wow...that is close. Looks awesome. Just need to upgrade to a stud conversion...helps avoid dinging your calipers.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
10-09-2011, 11:31 PM | #8 |
Rep 5,264
Drives: 2008 E90M3
congrats... definitely my next step is a bbk
- Jason P
:Have: 08 E90M3, Varis VRS Front Lip, LS3, ESS Supercharger, Arqray Exhaust, Neez Wheels :Want: VRS Carbon GT Wing & Cooling Bonnet, LCI Taillights :Videos: EnvyRidesTV, GPR 1, GPR 2, GPR 3, ///MFEST |
10-10-2011, 12:01 AM | #9 |
Rep 213
Yup. Studs will be nice. It is not easy to get the wheels on now. I have to be more careful. Once they are on though the clearance is about 1/4" at its closest point which is the corner of the head of the allen bolt. I measured it with some playdoh.
Royce M |
10-10-2011, 12:18 AM | #10 |
Rep 1,508
I fit checked the ST60 on my 18's before buying the ST40 instead. Spacers are a must for clearance which I did not feel comfortable as a long term and permanent solution.
Even with spacers, clearance is minimal. Probably between 1 and 2mm which is a bit concerning if anything gets stuck inside the rim (piece of rubber, rock, etc.). Be careful and check the inside of your rim often.
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates Previous: 2009 E90 M3 |
10-10-2011, 12:24 AM | #11 |
Rep 9,034
Nice pics, but I'd consider getting some APEX wheels. You'll have more clearance and they're not that much considering you have the BBK already.
And you won't need spacers. It really SUCKS when you realize you forgot the spacers as you're changing out to track wheels at the track!!
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
10-10-2011, 01:48 AM | #13 | |
Rep 213
Royce M |
10-10-2011, 01:50 AM | #14 |
Rep 213
10-10-2011, 02:49 AM | #15 |
Rep 15,818
dude how is your hub so damn clean??
10-15-2011, 12:07 AM | #17 |
Rep 697
Interesting, very tempting now that I know these can work with 18's. I put the st-60 template up to my stock 18's with 12mm spacers and it looked liek it fit with 1-2mm to spare. Do the front wheels stick out from the fenders with 15mm spacers? Any rubbing?
I wonder if the tight clearance will impede the airflow out of the top of the caliper. Last edited by RickyBobby; 10-15-2011 at 05:35 PM.. |
10-15-2011, 10:31 AM | #18 | |
Rep 8,077
10-15-2011, 04:01 PM | #19 |
Rep 213
Not sure exactly where they shaved the weight of the STR60 vs the ST60 calipers but according to the web site there is a 20% reduction of mass. I would assume there to be some difference in shape.
With the 15mm spacers the stock 18's are still tucked up under pretty well with 255 AD08's. I get some light rubbing of the fender liner at full streering lock but nothing major. The rubbing started with the 255 AD08's though. I don't have many pics at a side profile but here's one that I have on my phone. Royce M |
10-15-2011, 05:34 PM | #20 |
Rep 15,818
Dude I can't wait to see you at the track again!
Curious what your Big Willow times will be like now
10-17-2011, 02:06 AM | #22 |
Rep 213
Hi RickyBobby,
Had some time this weekend and was able to mount up the wheels with a 12mm spacer. Its even tighter but it fits. Here's a pic. I didn't have any playdoe this time but I checked with some feeler gauges and it looks like about ~1.5mm clearance to that allen head. Hope that helps. Royce M |
Timujin352.50 |
