11-02-2011, 12:58 AM | #1 |
Supreme Allied Commander
3886
Rep 54,510
Drives: F80 M3
HP Autosport | AFE High Flow Air Filter for E82 E9X and 1M N54T
These are direct replacement drop in filters for you N54T powered BMW 1M.
Pro 5 R Filter (Blue) This filter outflows the factory intake by 33%, increases performance and MPG. Constructed with 100% polyurethane on all four sides, this high flow, oiled OE replacement performance filter will outflow stock paper filter for improved horsepower and torque. Five layers of progressively finer mesh cotton gauze media provide maximum airflow for best performance results. Washable and reusable for multiple cleaning cycles, the tall open evenly space pleats provide excellent dust holding capacity for longer service cycle between cleanings. Integrated urethane bump seal insures tight, no leak seal over the life of the filter. Pro Dry S (Gray) This filter outflows the factory intake by 33%, increases performance and MPG. Constructed with 100% polyurethane on all four sides, this high flow "oil-free" OE replacement performance filter will outflow stock paper filter for improved horsepower and torque. Two layers of progressively finer mesh synthetic media provide maximum convenience and easy maintenance. Washable and reusable for multiple cleaning cycles, the tall open evenly spaced pleats provide excellent dust holding capacity for longer service cycle between cleanings. Integrated urethane bump seal insures tight, no leak seal over the life of the filter. This is an alternative to ITG, BMC, MC or K&N. Don't expect big hp gains, but air flow will be increased and you will see some hp and torque gains along with better throttle response. Choose either the Pro 5 R or the Pro Dry S You can order it directly here: https://www.hpashop.com/products/afe...5i-09-15-l6-tt https://www.hpashop.com/products/afe...5i-09-15-l6-tt Last edited by HP Autosport; 09-21-2023 at 01:41 AM.. |
01-03-2012, 07:21 PM | #4 |
3886
Rep 54,510
Drives: F80 M3
High Performance Air Filter
Both Pro 5R and Pro Dry are good in stock and ready to ship!
01-14-2012, 08:54 PM | #5 |
3886
Rep 54,510
Drives: F80 M3
BMW 1M High Performance Air Filter
Both versions are in stock guys!
01-31-2012, 02:46 PM | #6 |
3886
Rep 54,510
Drives: F80 M3
Filters are in stock!
