11-28-2011, 09:14 PM | #1 |
Rep 1
Cleaning IDrive, push buttons are sticking
Dose anyone know how to remove the Round IDrive and clean the buttons, I spilled some tea on the buttons and they keep sticking when I push them.
Thanks |
11-29-2011, 03:26 PM | #2 |
Rep 3,329
you can just pull up on the wheel it pops right out. Removing the button portion is a little more tricky because you have to remove the entire panel there to get it up.
F80 ///M3 6MT Avus Blue ZCP |
04-19-2012, 09:03 AM | #3 |
Rep 180
Can the individual buttons be popped out once you remove the controller? My menu button is sticking like crazy. Would rather not have to buy a $208 replacement controller! Thanks for any help!!!
08-18-2012, 06:59 AM | #4 |
Rep 1
Sticky idrive botton
Hi, i had the same problem and i cleaned it with brake cleaner, just spry it in and push the button down and lift it up with a smal screwdriver do it a few times, and it is free again. Dont forget to clean the spoiled cleaner and use siliconsspray to make the buttons shine again. And the problem is solved.
08-19-2012, 09:27 AM | #5 |
Rep 8,496
don't they have the PC keyboard cleaners you can use? And not the ones that just puff air...
http://www.amazon.com/3M-Keyboard-cl.../dp/B00006B7V9 |
08-19-2012, 02:05 PM | #6 | |
Rep 23
Drives: M3/530i
Specific electronics cleaning solutions are available everywhere.. like this one http://www.amazon.com/3M-Office-ELEC...+cleaner+spray |
08-19-2012, 08:29 PM | #7 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
i've had a lot of success with alcohol to remove dried up coke stains
and that's the one you drink, not the one you snort try a cotton bud dipped in alcohol and wipe all around the button and see if it helps a can of compressed air also doesn't hurt
