12-11-2011, 09:42 AM | #1 |
Rep 143
Build date (Month/year) from VIN?
Guys is there a way to fiqure out what month and year a M3 was built just by the VIN?
I have a friend looking at a some new ones and only has VIN's not the build dates that are on the door emblem so we are trying to fiqure out if they are 2011 or 2011.5 or 2011.75 Thanks. |
12-11-2011, 09:58 AM | #2 |
Rep 5,839
Go to realoem.com and key in the last seven digits of the vin and hit "search" (after hitting "enter" on the home page). After hitting "search" the "series", "body", "model", "region" and "prod month" info of the car will be filled in based on the vin.
12-11-2011, 11:57 AM | #3 | |
Rep 143
Thank you but it says "error E699193 not found" Any ideas? |
12-11-2011, 01:10 PM | #4 |
Rep 4,488
You can get it from the VO (which also lists the option code for everything on your car), but there's no easy way to access that. However, production month is listed on a sticker in the doorjamb, so if you're worried just check there (or ask for a picture of it if you're buying from a distance). If for whatever reason that's not possible, here's how to differentiate....
2011 from 2010: ZCP wheels would be a dead giveaway, otherwise if you're looking at a coupe the LCI tail lights didn't come to them until 2011. For a sedan, other than ZCP wheels I don't think there are any quick exterior differentiators between 2010 and 2011. 2011.5 from 2011: Having the Auto Start/Stop button under the stereo controls. I think the DSC Off button switched from having text to having the graphic with the word "Off" at this point, but that might have happened at 2011.75 instead, not sure. Also, if you see "Premium Package 2" or "Convenience Package" rather than "Premium Package" or "Technology Package", you have at least 2011.5 because that's when the packages changed. 2011.75 from 2011.5: The only new features for 2011.75 are Mineral White and BMW Apps, both optional and either of which would appear on a car's option sheet. Testing the presence of BMW Apps would require an iPhone with the BMW Connected app. Open the app, connect the phone to the car, and see if Twitter and Facebook appear in the ConnectedDrive area. Of course it's entirely possible to have a 2011.75 car with neither of those options, in which case it's exactly the same as 2011.5.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 12-11-2011 at 01:19 PM.. |
12-11-2011, 02:28 PM | #5 |
Rep 5,839
I know if I enter the vin for my '12 I get the same error because it was built in 09/11 but Realoem only has prod listed thru 08/11. However, if I key in the vin from my '09 I get the correct prod month/year. The only thing I can think of is if it has a prod month toward the end of '11 prod (say Jul or Aug) perhaps it's not in their database yet?
I know someone with an early '11 prod month. I'll get his vin, key it in and see what I get. |
12-11-2011, 02:41 PM | #6 |
Rep 1,705
interesting... I didn't know about these differances. I guess I have at least a 2011.5 since I have the auto start/stop. Not sure if any of the differances mentioned by jphughan would disuade me from a car I liked otherwise.
12-11-2011, 02:48 PM | #7 | |
Rep 4,488
2011.75 introduces no meaningful changes unless you get BMW Apps.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
