12-13-2011, 06:51 PM | #1 |
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
confirming the confirmed: N55 midpipes swap
yesterday took out the midpipes from the 2012 135 and swapped with the 1M. no change for the 135 but a good amount of pop and rumble for the 1M with the N55 pipes! perfect remove and bolt swap too.
highly recommended simple mod to the OEM exhaust setup! |
12-13-2011, 07:02 PM | #2 |
Rep 270
Can you explain more? More backfire type sounds, deeper tone, 25% louder at all speeds?
12-13-2011, 07:45 PM | #6 |
Rep 5,730
Drives: BMW i3 rex
JUST DO IT! ok ill do my best for a vid soon
12-13-2011, 07:46 PM | #7 |
Rep 5,730
Drives: BMW i3 rex
12-13-2011, 07:53 PM | #8 |
Rep 5,730
Drives: BMW i3 rex
12-13-2011, 09:40 PM | #13 |
Rep 5,730
Drives: BMW i3 rex
12-13-2011, 09:41 PM | #14 |
Rep 5,730
Drives: BMW i3 rex
12-14-2011, 02:10 AM | #16 |
Rep 5,730
Drives: BMW i3 rex
12-14-2011, 02:19 AM | #17 |
Rep 7,642
12-14-2011, 11:23 AM | #18 |
Rep 31
The secondary cats are required to keep the vehicle emissions in check while the diagnostic is run on the rear O2 sensor. This is required each drive cycle, where the ECU modifies the fuel air mixture into a region that makes the primary cats less effective in reducing emissions. I believe this revised diagnostic was implemented in 2010 regulations.
Once the diagnostic is complete, the primary cats are sufficient to meet emissions. Since this diagnostic will likely complete within the first few minutes of a drive cycle, you should have no problem passing a smog check, based on emissions measured. |
12-14-2011, 12:51 PM | #19 |
Rep 31
The N55 primary cat should have been designed with the rear O2 sensor integrated mid length so it can complete its diagnostic without the use of a secondary cat.
12-15-2011, 12:18 AM | #20 | |
Rep 258
12-15-2011, 01:16 AM | #21 |
Rep 31
Correct. The rear O2 sensor I was referring to is the one right downstream of the primary cat. It is the one that needs the diagnostic...which causes emissions breakthrough of the primary cat.
12-15-2011, 01:23 AM | #22 |
Rep 31
This means that the secondary cat is only necessary to contain emissions for a very short duration during each drive cycle.
So yes, removing it will increase emissions a small amount for a short period of time, but this will not be detectable with a sniff emissions test (since the test is on a warm engine after the diagnostic would have completed). It is still, technically illegal to remove the secondary cats for on road use, per the letter of the law. |
