12-15-2011, 12:08 PM | #1 |
Rep 372
SWS8 popping sound with volume turned up
Setup:
Rockford 300/2 LC2i Technic Harness 2 sws8xi 2ohm. Up until recently it's been perfect, both subs random ally blew. So I replaced them. Turned them on last night and they sound OK at light volumes. As you go to medium volume they will pop randomally / distort / crackle. Something not right. Gains on amp went up and down on the LC2i no change same with crossover. Both subs do this. Help? |
12-15-2011, 12:38 PM | #2 | |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
http://www.m3post.com/forums/showthread.php?t=623617 |
12-15-2011, 01:43 PM | #3 |
Rep 13,018
Set the LC2i AccuBASS level and threshold to the absolute minimum: http://rs.audiocontrol.com/company_38//LC2i_OM.pdf
There is no need of any AccuBass in our cars. Also, the LC2i Main outputs can be used, as the inputs to the LC2i are already low passed. That should avoid any processing/adjustment of the bass thru the knobs. |
12-15-2011, 01:52 PM | #4 | |
307
Rep 13,093
12-15-2011, 03:02 PM | #5 |
Rep 13,018
The popping comes from the Accubass settings increasing bass notes unnecessarily. The Main outputs do not pass thru the Accubass circuitry.
So if you want to use/adjust the Accubass feature then you must use the Bass output. To me, I use the Main outputs as -stated before- no bass notes needs to be processed in any of the OEM audio systems. The main purpose of the LC2i and the Enhanced Audio system is to handle reliably the 150W/30V peaks of the OEM amp woofer outputs, not to process the bass. |
12-15-2011, 03:07 PM | #6 |
307
Rep 13,093
Ok. I set all 3 knobs on top to their minimum and the threshold dial on the side to it's lowest as well.
12-15-2011, 07:16 PM | #7 |
307
Rep 13,093
Well I did the above and now I have less bass than before.
12-15-2011, 08:26 PM | #8 |
Rep 13,018
Of course you do, the AccuBASS was increasing the bass automatically for you and then causing the pops when the level exceeded whatever threshold you were using.
Now you have exactly the same bass level output of the OEM Amp if you are using the LC2i Main outputs, no artificial bump in bass. You have to adjust the bass manually to your particular taste and set it just below the clipping/pop level. |
12-15-2011, 08:31 PM | #9 | |
307
Rep 13,093
12-15-2011, 08:34 PM | #10 | |
Rep 13,018
Is up to your particular bass level taste. |
12-15-2011, 08:43 PM | #11 |
307
Rep 13,093
12-15-2011, 09:13 PM | #12 | |
Rep 372
12-15-2011, 09:27 PM | #13 |
Rep 13,018
12-15-2011, 09:31 PM | #14 |
Rep 13,018
If your original SWS-8 blew then by definition your system was not perfectly fine. What your are experiencing now most probably is the same bass level/gain issue that blew your SWS-8 to begin with.
12-15-2011, 09:49 PM | #15 | |
Rep 372
From 50-80hz lp crossover and a gain of 3-8 before on the rockford it would not distort nor pop, ever. It lasted 6 months at gain of 7. One cold morning (20 degrees) I turned the car on with the music cranked to near max and in a clean boom, both speakers popped. I replaced them and turned the gain back to 1-3 and it now pops every 6-7 seconds. Somethings off. |
12-15-2011, 10:06 PM | #16 | |
Rep 13,018
So it looks to me that perhaps a spike at car turn on at either the RF amp or the LC2i 12V input may have caused the SWS-8 pop. Which could also mean that either the RF amp or the LC2i may be also damaged. |
12-16-2011, 09:06 AM | #17 |
307
Rep 13,093
Got mine squared away. Thanks Technic!
12-16-2011, 02:55 PM | #19 |
307
Rep 13,093
I think our problems were similar but not the same.
Have you tried taking the harness out and eliminating all the aftermarket stuff from the loop to see if the popping is still there? I mean you're dealing with 4 different parts, each needing to be diagnosed to find the trouble source. |
12-16-2011, 03:32 PM | #21 |
307
Rep 13,093
