02-21-2012, 09:26 AM | #1 |
YNWA
194
Rep 1,814
Alignment done... steering wheel still tilted
Hi guys,
I had an alignment done on my M3 yesterday. Its not pulling either way now everything seems good, but my steering wheel is still somewhat tilted to the left when driving straight. Anyone know why this could be happening? Thanks!
Imola Red ZCP F80 M3
02-21-2012, 09:40 AM | #2 | |
Rep 4,445
Sounds like they forgot to center your steering wheel when they did the alignment. Go back should be a quick fix.
02-21-2012, 10:59 AM | #3 |
YNWA
194
Rep 1,814
Thanks man. Ill give them a call and ask!
02-21-2012, 06:03 PM | #4 |
78
Rep 684
+1. Another possibility could be the tires. Do you have uneven wear between the left and right tires? For example, a lot of guys who go to the track have off-centered steering wheels.
02-21-2012, 11:58 PM | #5 |
BimmerPost Supporting Vendor
732
Rep 3,735
The tech that does your alignment must make sure that it is alignment with correct weight in the car (at the least a drivers weight) and a decent amount of fuel.
A steering wheel holder should also be used when adjusting front end alignment. 3 things that must be checked: 1) Thrust Angle must be 0.00. 2) Steering wheel must be centered and locked in center position. 3) Front and rear subframes must be centered and in true square position (usually a problem if there has been bushing work, or subframe work done. In rare cases, the subframe can shift, but again, rare.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
02-22-2012, 08:57 AM | #6 |
YNWA
194
Rep 1,814
Thanks guys. I called them yesterday and im taking the car in this afternoon. He said he's going to fix the problem for me so ill keep you updated. Thanks again for the comments you guys are awesome!
02-23-2012, 06:39 AM | #7 | |
Rep 4,445
I make the alignment guys throw in 200 lbs of sand bags in the driver seat (after the protective cloth is apply)
02-23-2012, 04:45 PM | #9 |
YNWA
194
Rep 1,814
So i went in again and they checked the alignment. Im not sure exactly how it works, but they showed me that everything was perfect and the wheel was still somewhat tilted to the left. They made some minor adjustments and said it was a cosmetic change to make the wheel straight. Driving the car feels great now and the wheel sits perfectly. They said it could be due to the Hankook tires, but im not sure. Any idea why the alignment would be perfect and the wheel still off? Anyways just thought id throw in a quick update. Thanks for the help guys!
03-01-2012, 10:55 AM | #10 |
732
Rep 3,735
Glad you got it all worked out!
03-01-2012, 11:24 AM | #11 | |
Rep 2,991
03-01-2012, 11:49 AM | #12 |
732
Rep 3,735
Thats possible, but this seems like a common case where the alignment technician didn't take care to make sure everything along with the steering wheel is perfect.
03-02-2012, 11:08 AM | #13 |
YNWA
194
Rep 1,814
Yup. Definitely just an issue with making the steering wheel straight. It was an easy fix. Good info for anyone having this problem. Thanks again guys for all the help!
