BMW M3 Forum (E90 E92)
EXXEL Distributions
      02-24-2012, 02:05 AM   #1
werly
Taiwan
53
Drives: 2011 MR E92 M3
Did anyone DIY the Vorsteiner CF hood??
Before the hood arrives next week I would like to get some advices on installation, yes I am doing it by myself and possibly another friend or my brother
From what I heard it is basically a easy swap without modification. I was inspecting the OEM hood the other night and found some areas that I am not 100% sure how to:
1. Driver's side lift: how to remove them to fit onto the cf hood? just yank it out?
2. Located a bit below the hood lift there is this as picture shows. Do I unscrew all 3 including the silver one and transfer them to the cf hood? Do I have to disconnect the battery before I unscrew the silver nut?
3. The rest: I assume they just need to be unscrew and transfer to the cf hood?
I haven't really seen the construction underneath the Vorsteiner hood hopefully it is easy swap like I have heard.
      02-24-2012, 08:21 AM   #2
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Should be fairly simple assuming it fits well. Also, you will probably have to delete the hood struts when you put the new one on.
      02-24-2012, 10:19 AM   #3
werly
Taiwan
53
So I can't have hood struts for my the cf hood?
either way, do you know how to remove it
      02-25-2012, 08:14 AM   #4
BimmerM
BimmerM's Avatar
Drives: '21 F95 X5 M C, '11.5 E92 M3 C
2013 BMW X5 M  [0.00]
2011 BMW M3  [0.00]
There's a metal clip that you pop out with a flat head screw driver. Once that clip is out it will slide out. Do not attempt to yank it out before you remove the retaining clip.
      02-26-2012, 12:24 AM   #5
werly
Taiwan
53
I see, but the two struts still go on to the CF hood?
      02-26-2012, 12:59 PM   #6
THE TECH
THE TECH's Avatar
307
You will need to ask Vorsteiner, but I would recommend against it. The struts are too strong for a CF hood and you could run into some issues if you use them.
m3post
