02-28-2012, 03:36 PM | #1 |
Rep 204
BMS Oil Catch Can Install - Review
Just wanted do give a quick review of the BMS OCC for the 1M. Terry went through some R&D with the install on the 1M and things crossed over from the 1 series pretty easily.
The unit is really well made and ultra stealthy from the design to mounting location. As far as the quality of the OCC, its design and build look flawless, below you'll see some photos of it mounted on the car and an image borrowed from their website. Install was very straight forward, although there was a minimal bend/crimp issue with the rear hose. Terry is supplying a hose and install instructions to fix the issue that were run into initially on the 1M. Overall, an amazing unit and a small investment for longevity of your engine Last edited by Drace1; 02-28-2012 at 03:48 PM.. |
02-28-2012, 03:41 PM | #3 |
The Stig!
54
Rep 889
Drives: 2008 135i 6MT
They are nice little units! After a month and 2-3 thousand miles i emptied about 2 oz out of mine last night!
What are you wanting to see Dack? I haven't taken any pics of mine simply because i've seen alot of pics online and they all looked pretty similiar to mine. LOL
2008 135i - FBO + JB4 15ohm + Water Meth
02-28-2012, 03:41 PM | #4 |
Rep 204
Sorry i tried using Imageshack which I typically used but for some reason they're making me sign up and tried another provider which obviously sucks (Chose their Forum Option)...
Lets try this again! lol |
02-28-2012, 03:43 PM | #5 |
The Stig!
54
Rep 889
Photobucket!
02-28-2012, 03:46 PM | #7 |
Rep 204
From what Terry told me its a tad bit different but still a tight fit. I think the instructions are all up to date on the site.
02-28-2012, 03:55 PM | #9 |
Rep 204
Here are Terry's comments from when I last spoke to him:
"The new hose is a bit better but it's still a tight fit. In the guide there are now directions to notch the back of the plastic engine cover to make it a bit easier to go in." |
02-28-2012, 04:18 PM | #10 | |
Rep 739
I just ordered a kit which should be arriving tomorrow.
02-28-2012, 05:08 PM | #11 |
Rep 204
Nothing really, it was just a bit tough to adjust it perfectly... The original hose is still installed on the car with 0 issues. Im assuming he just made a slight mod for future hoses somehow. This was installed quite some time ago when the 1M first came out and no one had really installed the OCC on a 1M.
02-28-2012, 11:44 PM | #12 |
Rep 802
When emptying out the can, do you have to remove anything to get to it?
I just placed an order 3 days ago, I hope I get the updated hose... What's the install like, even with the old hoses? On a scale from 1 to 5... 1 being easy, 5 being the covers on the back of the headlights.... lol |
02-29-2012, 06:17 AM | #14 | |
Rep 1,293
02-29-2012, 09:44 AM | #15 |
Thread killer
646
Rep 1,896
I was familiar with the carbon buildup issue when I was shopping RS4s but despite browsing this and other forums, I'm still a bit in the dark as far as how important this mod is (e.g. on a scale of 1 to 10) to N54 longevity? Would anyone consider this to be something along the lines of The Single Most Important Modification if one plans on keeping the car for a long time?
02-29-2012, 09:57 AM | #16 | |
Rep 2,091
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2024 718 GT4 RS | Arctic Grey |
03-01-2012, 09:24 AM | #17 | ||
Rep 204
03-01-2012, 09:27 AM | #18 | |
Rep 204
03-01-2012, 11:58 AM | #19 |
Joint Chiefs of Staff
4927
Rep 116,006
There is only one type of hose and it fits the 1M just fine same as any other N54. A hose revision was made to make the 2 piece in to 1 to lower production costs but it has the same physical dimensions and does not change fitment, etc. If you're unable to get the hose to sit without kinking one option is to just leave the rear engine cover bolt off back there You'll never notice it with the cowl on. Another is to notch the plastic engine cover like this:
Also, here is what the BMS OCC caught after two days of racing their 135i. Imagine this junk coated all over the inside of your intercooler, chargepipes, and intake valves. Yuck! You can just click on my sig to order or get more info on it Mike |
03-03-2012, 02:53 PM | #21 |
Rep 163
I'm having problems removing the clips that hold down the wires to the two sensors (on passenger side and drivers side). How are people removing these clips from the cowl? I'm not talking about removing the actual sensors from the cowl, but instead the wires that lead up to them. I guess one option would be to cut the tape, but I'd rather just unclip the wires if possible.
03-04-2012, 11:59 PM | #22 |
Rep 739
I installed mine this past weekend. The install went smoothly. The only slow part was removing the strange hose connections on the OEM tube.
Also, I found it easier to remove the 45° elbow on the intake tube and then install the u-bend hose instead of installing it while in place. I cut the tab on the plastic engine cover. It's so far back there that no one will ever see it, and it really does make a huge difference as far as room goes. Here are some pics:
