      03-05-2012, 08:59 AM   #1
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
Bilstein PSS 10s for your 1m
Hey so i have not seen any talk about bilsteins up here.
Im getting a set from a friend thats selling his 1m and hes giving me a really good deal.
Im paying them off right now but im wondering why theres no talk about them.
There just as good quality of KW's if not better and i just want to make sure im investing my money on the right coilovers.
Any talk about the bilsteins will help. Are they on the level of asts ?
Are they better than KWs?
I cant wait !!!
      03-05-2012, 09:04 AM   #2
pixelblue
pixelblue's Avatar
140
Drives: the silver bullet
2010 135i  [8.90]
I've been running pss9's for the last two years and they are great. they were specifically designed for the 1 series with proper spring rates. I would say the pss10's are on par with kw3's. you may want to look into custom spring rates to get the best out of them.
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
      03-05-2012, 09:50 PM   #3
speedyjoe
Drives: E46M3/1M
I am also thinking of PSS10 but some says it creates lots of noise on 1M.. Please let me know how you feel after u have it on.
      03-06-2012, 12:40 AM   #4
CDR_UK
Drives: AW 1M
Had pss10 on my 135i for a few months and was not happy. The minimum drop was too low, there was never a good balance between compression and rebound in the rear, the max damping level was not hard enough for track usage, and one of the rear adjusters jammed after a short while. Took almost a year for bilstein to sort it out. In the meantime I went with KW clubsports (which are the same as v3 in the rear on 135i) and it was night and day - all problems were addressed. Would not bother with pss10 again.
Probably going for jrz rs1 for the 1m, otherwise kw clubsports.
      03-06-2012, 10:12 AM   #5
PunjabiM3
PunjabiM3's Avatar
Drives: M5 CS
I just installed the KWV3 on my 1M this past weekend and so far I like them very much.
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia
2020 BMW X7| Mineral White
2024 718 GT4 RS | Arctic Grey
      03-06-2012, 10:53 AM   #6
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
Hmm well im picking up the set pretty soon to install it. To be honest from all the reviews ive heard about bilsteins vs KWs bilsteins win hands down. Im pretty sure the spring rates on the. Coilovers tho are meant for the m3 can anyone help me out on spring rates so i could buy swift springs to mate on my bilstein dampers??
      03-06-2012, 10:55 AM   #7
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
What should be the front spring rate and the rear spring rate?
Also im more of a daily drive but will use them on the track as well. I want a comfortable ride if that helps with determining spring rates
      03-06-2012, 11:06 AM   #8
pixelblue
pixelblue's Avatar
140
2010 135i  [8.90]
contact Harold at HPA. he should be able to get you proper spring rates
      03-06-2012, 11:15 AM   #9
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
Just did he said the rear should be easy to upgrade since its not a true coilover the front is a different story though.
I need to find the spring id and length for the front so i could upgrade.
      03-06-2012, 11:31 AM   #10
pixelblue
pixelblue's Avatar
140
2010 135i  [8.90]
not sure why you can't upgrade the front springs. I would check with a few more vendors. don't worry about the nay sayers. PSS10 are quality piece. they do drop at least an inch though but then you have a lot of space for a drop
      03-06-2012, 11:36 AM   #11
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
Yea there on my friend sals car over at autocouture.
Also all i have heard is that bilsteins are better quality for the price than KW's . So im surprised to hear that review early in the thread
      03-06-2012, 11:42 AM   #12
PunjabiM3
PunjabiM3's Avatar
Drives: M5 CS
Funny I have heard the opposite on the KW vs Bilstein from a lot of people: KW being better than Bilstein. Have read many threads on people having issues with Bilstein and Bilstein being terrible about getting the issue resolved. I think either one would be just fine though. I had Bilstein on my 997 C2S and they had no issues. I can say the same for Ground Control coils on my e46 M3. Bilstein is only a single adjustable system so not as good as KWV3 in terms of adjustment and perhaps ride quality.
      03-06-2012, 12:01 PM   #13
pixelblue
pixelblue's Avatar
140
2010 135i  [8.90]
well you know how these things go. people always brag about how their's better. plenty of examples in this forum, if you know what I mean
      03-06-2012, 02:47 PM   #14
lcrain
Drives: e36 m3, TT-RS
From my understanding the Bilstein pss10s have the least amount of adjustability (only one adjustment knob). This may be a benefit or a negative depending on how much you plan to track or how many adjustments you plan to make. The pss10 has one knob that adjusts the rebound and compression together. For someone who doesn't know suspension geometry very well it is as easy as softer/harder. The other options out there (KWv3, KW comp, AST4200 etc.) have height adjustment and have the ability to adjust the compression and rebound separately.
I have heard great things about the bilstein's for different cars. They make a solid product. Most of the guys on here with modified suspensions are doing so for track capabilities and being able to adjust more is seen as a definite plus. If you just want to adjust the height and play with the overall "firmness" a little then the pss10s will likely be adequate. They are also cheaper than the other coils that allow for finer adjustments...so that is a plus too.
      03-06-2012, 02:50 PM   #15
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
I believe bilstein just raised the price of the pss10s if im not mistaken. They are more expensive than v3s now
      03-07-2012, 12:39 AM   #16
CDR_UK
Drives: AW 1M
My comments above are purely objective, and based on driving pss10 Vs Kw cs on street+track. The pss10 were lousy, the kw's were great. I no longer have either. Based on my experience I just offered my honest opinion about these dampers, and I would never recommend pss10 to anyone.
      03-08-2012, 07:50 AM   #17
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
Haha the true question is are bilsteins better than then stock suspension?
Also are they better than v2s? Yes
Maybe KW v3s have more adjustment but bilsteins have some of the last monotube dampers which are basically race dampers from what i heard. I should have them on my car in about a week so ill let you guys know!
      03-08-2012, 07:52 AM   #18
pixelblue
pixelblue's Avatar
140
2010 135i  [8.90]
let us know your impression once you had the chance to evaluate them
      03-31-2012, 10:47 AM   #19
NTTY
NTTY's Avatar
Switzerland
38
Drives: G30 M550xi
+1
Got the PSS, lowered too much the car even at the highest position, so I had to slightly modify them. Compression/rebound were both very bad, so I had to make this modified by a professionnal. Then I have been happy until they started making noise. I've been told it happens with the PSS. I would not recommend them either.
2018 M550i Sepia-Violet
1addicts
