03-21-2012, 12:40 PM | #1 |
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
WAGNER tuning new FMIC received and installed
Getting near the end of the rope for bolt on power mods, and this was my final answer: the WAGNER tuning EVO intercooler. The company shipped it out from Germany very well packaged via UPS expedited.
My readings pointed to the ETS and the Wagner as candidates. Harold @ HP Autowerks gave the best price for the ETS so if anyone is going with that FMIC contact him! But this is what won it for me: the Wagner 1M intercooler has a step design that results in about 85% greater surface than stock IC, it does not require any trimming, cutting and is total plug and play using all factory mounting points without any bumper removal. The Wagner unit was made in Germany and is bar and plate in design. I found out there are two designs out there, bar and plate vs tube and fin (the latter being more popular in Europe, the former more popular in NA). This is where I got my intercooler from: http://wagner-tuning.de/EN/products/...ntercooler.php Started work with my buddy Sam @ 2300. Ramped the car up and there we were: I'm not good at writing DYI's but essentially you remove the plastic undertray with ten billion bolts (that alone takes time!), then you loosen two factory bolts from under the OEM intercooler, loosen two hose clips and then wiggle the OEM intercooler down. There is an additional plastic piece that needs to be removed on the passenger side top before you can install the Wagner FMIC in but after that is done, it is all smooth sailing! The Wagner sends you a set of extended bolt, plastic spacer and nut you have to use to mount. Replace under tray and voila, all done. Pics comparison of the Wagner vs OEM Took 3 hours to do the 1M (more than half of that was sheer dumbness like losing a black under tray screw and looking for it on my black garage floors! ). After finishing the 1M we got to work on Hackulo's E92 335 and we finished it up under 1hr. too tired to drive the car last night after install and my commute to work is too short to really comment on its gains over the stock FMIC but will update this again at a later time. |
03-21-2012, 12:44 PM | #3 |
Rep 5,730
Drives: BMW i3 rex
03-21-2012, 02:45 PM | #6 | |
European Editor
10628
Rep 22,992
Wagner actually makes two kits. One for the 135i and one for the 1M - although the sizes listed by Wagner are the same. The 1M unit is 30 euros more than the 135i unit. 135i version Size 520 x 210 x130, 11.752cm³ Volume (OEM stock FMIC 510x130x110mm, 7293cm³ Volumen) http://www.wagner-tuning.de/EN/produ...rcoolerENG.php 1M version Size 520 x 210 x130, 11.752cm³ Volume (OEM stock FMIC 510x130x110mm, 7293cm³ Volumen) http://www.wagner-tuning.de/EN/produ...ntercooler.php |
03-21-2012, 05:16 PM | #7 | |
Rep 13
Can you confirm that there is definitely no cutting required when fitting this intercooler? How many inches does the Wagner step section cover the flow to the radiator? Is the whole of the Wagner face directly open to the gap in the front bumper or is some behind the bumper at the top and the bottom of the face? Also, are the dimensions that Dack has posted above just the dimensions of the OEM and Wagner cores or do they include the end tanks? If you could measure your OEM that would be an added bonus, not necessary though. Many thanks in advance for taking the time to answer this for me. |
03-21-2012, 05:27 PM | #8 | |
Rep 5,730
Drives: BMW i3 rex
03-21-2012, 06:32 PM | #10 |
Rep 639
Drives: E92 335i
3 hours work plus bring the food to u. I feel I am like a cheap maid.
lol no cutting no trimming at all. plug and play. very ns product. I am really happy with this on my 335i. M.I.G. ftw.
cheap fast cars arent reliable reliable cheap cars arent fast and fast reliable cars ARENT CHEAP |
03-21-2012, 06:51 PM | #11 | ||
Rep 5,730
Drives: BMW i3 rex
im also writing to your headquarters! |
03-22-2012, 02:04 AM | #13 |
Rep 2,366
Drives: 1 M Coupe
wow really like the fact you don't have to take the front bumper off. Definitely something im going to consider.
03-22-2012, 10:10 AM | #14 |
Rep 3,094
You feel like a cheap maid? How should I feel if Im the one doing the work for the cheap maid??? What does that make me?
03-22-2012, 11:47 AM | #15 |
Rep 275
03-22-2012, 09:37 PM | #16 |
Pablo
39
Rep 263
Is the Wagner bar and plate construction? I read another post where the Helix guys were ragging on Wagner for copying their design concept and saying the construction was inferior tube and fin.
BMW PPK V2, M3 26mm sway bar, M3 front control arm kit, M3 steering wheel, BMW 313 wheels w Michelin PSS
03-22-2012, 10:40 PM | #17 | |
Rep 5,730
Drives: BMW i3 rex
03-23-2012, 05:42 AM | #18 |
Rep 639
Drives: E92 335i
lol so u r the maid's maid. call MSM lol
03-23-2012, 12:32 PM | #20 |
Rep 5,730
Drives: BMW i3 rex
03-23-2012, 01:48 PM | #21 |
Rep 3,094
03-23-2012, 01:53 PM | #22 |
Rep 4,159
Drives: 1/18 Monte Carlo Blue E92 M3
Looks like a good alternative to the no cutting ETS intercooler. Would be great to get a third person party to do a comparison between em with actual data/numbers.
