New 2009 2010 BMW Z4 - ZPOST
      03-21-2012, 02:35 PM   #1
bmwZ
bmwZ's Avatar
Norway
202
Drives: Z4 35i ESS
Adaptive suspension with H&R Springs
Hi!
I`m new to the E89 forum, but have used the E85 forum much
I will soon buy me a Z4 35i and want to lower it with H&R sprngs as they give the car a perfect look.
My question is: Can I buy a car with adaptive suspension and still use H&R springs?
[SIGPIC][/SIGPIC]
      03-21-2012, 05:19 PM   #2
danielC
Drives: 335
Originally Posted by bmwZ
Hi!
Yes..
      03-22-2012, 12:56 AM   #3
ChuckB
ChuckB's Avatar
Drives: 2020 X2 2.0i
This is the same setup I have, works great, looks pretty good, check the garage. The only thing to be added are 5mm spacers on the front and 10mm spacers on the rear to bring the wheels out almost even with the body. Going a bit wider at the back also reduces some of the understeer when pushed hard.
      03-22-2012, 06:56 AM   #4
baldguyj
baldguyj's Avatar
Drives: 2010 Z4 e89 35i Sdrive
Chuck, that looks great but two questions:
1. Which H&R springs did you use (Sport, Race, OE...) and why?
2. I do push my Zed hard on the track 3 - 4 times a year and debating on order of mods, it has the understeer but also a little loose in the corners was considering sway bars then springs but the spacers are a cheap way to help with understeer, now my question, did the springs help with the “looseness” ?
      03-22-2012, 12:59 PM   #5
ChuckB
ChuckB's Avatar
Baldguyj, we don't get a choice for road cars (German T.U.V.), so I could only get H&R part # 28987-1, which probably equate to the Sport version available everywhere else.
I found the springs lowered the car perfectly as far as the optics go. I have the Adaptive suspension, which, having driven both versions, does help a lot, but still had issues with the rear of the car hopping on every irregularity when cornering hard, the springs did not remove all of it, but did improve it noticeably. It did help a bit with the oversteer, but not as much as I would have hoped, but you can feel it coming on much better. I also changed the rear camber from -2.5 to -1.5, which also helped with the understeer a bit, but at the expense of high speed stability, but again not enough to keep me from hitting the limiter when traffic allows. So I am hoping the spacers take just a little more understeer out, then I think I will be happy.
So to specifically address your questions;
Sport Springs
Yes, it did reduce, but not eliminate the looseness. But I find everything so far does allow a lot more confidence when pushing hard. Will let you know how the spacers weigh in after next week.
      03-22-2012, 08:39 PM   #6
baldguyj
baldguyj's Avatar
Chuck, great explanation! So there are advantages and disadvantages to everything! We can get several parts here and mod our cars ‘easier’ but you can drive your car the way it was designed on a daily commute and I have to pay $300 - $600 a weekend to track my car. Oh well! Interesting you changed the rear canter I was going to change my front since the last track tore up the outside edge, hence need more negative cantor to compensate. I worry that dropping the car much and added spacers will cause some problems. Look at pictures and you can see at Sebring I already have a lot of compression and yes I have adaptive suspension as well. My thought was to start with sway bars to correct a bit of the roll, add a bit of negative cantor to the front but with any good experiment we cannot change too many variables or you don’t know what made the difference.
      03-22-2012, 08:41 PM   #7
baldguyj
baldguyj's Avatar
Don't mind the bugs, we have a little problem called love bugs down here in Florida
      03-23-2012, 01:09 AM   #8
ChuckB
ChuckB's Avatar
The biggest issue with the adaptive suspension (and I love it and wouldn't pull it off) is that a lot of the changes are compensated for by the computer, in particular the "fight" between the sway bars and the "yaw control" built into the adaptive suspension. While you do get an improvement, it is not as much as the non-adaptive suspension, according to Dieter of the "Z-Racing team", but he still recommends the sway bars, and setting the rear soft.
There are a few rumors floating around over here about a possible "Cup" version of the Z4 to be announced this summer, but no authoritative source yet! So we are hoping and waiting to see if this turns out to be true, and if so what parts they will bring out. Appears to be a spin off of BMWs return to racing now that they have factory racing support for the 1 series, the Z4 GT3 and the 3 series and they are back into DTM this year. So I know what I want for Christmas this year...
Appologies to the OP for highjacking this thread...
      03-23-2012, 09:15 AM   #9
baldguyj
baldguyj's Avatar
Originally Posted by bmwZ View Post
Hi!
From H&R web site, they even have specifics for With and Without Sport Suspension
http://www.hrsprings.com/scripts/app...Find3&MakeID=4
      03-23-2012, 11:15 AM   #10
ChuckB
ChuckB's Avatar
What they call the Sport suspension is the Adaptive Suspension.
      03-23-2012, 04:23 PM   #11
bmwZ
bmwZ's Avatar
Norway
202
Drives: Z4 35i ESS
Thanks a lot for good answers. Have KW V3 on my E85 Z4 now, but do not want to change the adaptive suspension when moving to an Z4 35i.
Looks like the H&R springs lower it perfect
[SIGPIC][/SIGPIC]
      03-24-2012, 07:17 AM   #12
ChuckB
ChuckB's Avatar
Th drop is nice, it has never bottomed out, or touched the wheel well even when pushed really hard, and it corners unbelievably flat
zpost
