03-27-2012, 04:39 PM | #1 |
Rep 253
Drives: '08 135i M-Sport Coupé
Condensation in headlight housing after AE LED install
I received a pair of BMS angeleye LED upgrades in the mail yesterday. I went straight to installing them.
After installing them I ran the car through the car wash. A few minutes after pulling out of the washer, I received the dreaded Adaptive Headlight Failure error light: It actually had a different light on at first but I can't remember what it was or what it looked like, but it was something in relation to the headlights. The error code goes away when driving for about 3-5 minutes at a time but it comes back. I've left the housing off the back of the headlight while it sits in the sun outside in hopes of drying out the condensation. Is my headlight trashed or can I just replace the xenon bulb? If the whole headlight needs to be replaced (I'm out of warranty), I'm just going to sell the good headlight along with the bad one, and buy the Depos. Is there any way for me to troubleshoot the headlight to see if the housing needs to be replaced or if it's just the bulb without having to waste the $$ on a new bulb? Thanks!! |
03-27-2012, 04:52 PM | #2 |
Rep 2,926
I have posted the symbol you are receiving via picture below.
Unfortunately since you have a 135i with Xenons -- you will not be able to just pick up a set of DEPOs since they use Halogen settings. You will more than likely be forced to buy new headlights or used ones from the forum/eBay. Hope this helps!
03-27-2012, 04:56 PM | #3 | |
Rep 253
There's no way to convert? Or is there a way to just replace the part(s) that are malfunctioning? |
03-27-2012, 05:02 PM | #4 | |
Rep 2,926
Try to see if your mechanism is working by turning your wheel and seeing if your lights turn with you. If not its the electric motors. Also make sure that no lights are out as it might be a simple bulb out fix.
03-27-2012, 07:06 PM | #5 |
Rep 253
Ok I let it dry out and now it's just giving me a bulb out error... Am I in the clear??
03-27-2012, 07:12 PM | #6 |
Rep 253
Ugh, the light came back. :'(
03-27-2012, 07:13 PM | #7 |
Rep 2,926
Have someone hop in the car and test the "adaptive lights" by moving your steering wheel and see if the headlights move with it.
Also look and see if there are any bulbs out?
03-27-2012, 07:23 PM | #8 |
Rep 253
What do you mean check to see if bulbs are out? I mean the projector light is out but I thought if the moisture fried the adaptive headlight electronics the light would be out anyway right?
03-27-2012, 07:45 PM | #9 |
Rep 341
I'm not too sure how bms angel eye bulbs look like but sometimes if the upgrade comes with the ballast (big chunky thing where you have to attach the bulb to before installing it), people put it in the headlight housing. This restricts the movement of the adaptive headlight and can trigger the warning lamp you see.
Not sure if this is the problem you are having but thought I let you know just in case. If you already knew about this and it's not the cause of the problem, I'm not too sure myself what's going on.. |
03-27-2012, 07:58 PM | #10 |
Rep 2,926
Not necessarily. Is there anyway to tell if the adaptive housing moves even if the bulb is out? From the given info its hard to tell whats wrong as there could be numerous electrical shorts (bulbs/ballasts/adaptive motors/etc...)
The only downsides of having Xenon lights Wouldn't hurt to take it in to BMW to have them write it up so you know exactly what you would need then go look elsewhere?
03-27-2012, 08:09 PM | #11 |
Rep 2,251
can you make sure there is nothing in the way of the Adaptive headlights from moving. I remember someone damaging their headlights because the ballasts were placed somewhere and prevented them from moving.
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB |
03-27-2012, 09:28 PM | #12 |
Rep 253
Well, now that I'm thinking about it, I guess I'll try taking out the bulb from the left (working) headlight and putting it in the right (malfunctioning) headlight and see if I get it to light up.
Maybe the bulb out error is coming from the right headlight and the adaptive malfunction is coming from the left headlight? I'm keeping my fingers crossed. |
03-28-2012, 10:52 AM | #13 |
Rep 253
Didnt work.
03-29-2012, 11:17 PM | #14 |
Rep 10,721
Drives: M4 CS. Former G82, x2 F82, F80
Sorry about this, but let's see how close I am to what happened.
You installed the AEs, and were able to get the cover back on the drivers side light. However, due to the extremely tight fit on the passengers side, you were unable to get the cover back on the headlight after AE install (or at least not on completely, one bitch clamp down doesn't count for this job). You said screw it, I'll get back to it later, then forgot about it until you went through the car wash. If this is what happened, or I'm close, your headlight is toast. |
03-29-2012, 11:42 PM | #15 |
Rep 3,732
Drives: BMW S1000XR
+1 ^^ i had the same problem due to a failed gasket. I went through a high pressure wash and it killed my xenon and adaptive light on the drivers side. I am lucky b/c I am still under warranty and I understand BMW charges a lot of $$$$ for a replacement. I would call Stealth Auto and ask them if you would be able to install Depos and have the car coded for them.
BMWCCA member |
03-30-2012, 12:42 AM | #16 | |
Rep 253
03-30-2012, 02:45 AM | #17 | |
European Editor
10624
Rep 22,992
Before you do that you might wanna do some more research on this(searching here). In the past there have been memebers that have swapped out the bulbs or ballast or FWM(footwell modules) only to blow up the other side of teh system. The problem is that the headlight isn't just a headlight anymore it also has some circiut boards inside it. Once it gets wet - its toast. (at least from what I have seen posted here). Then it blows the ballast and FWM. I think your bulb is probably ok. And these headlights are not cheap to replace! $1,500 or so. The best thing to do is put the car back to stock... then take your car into a dealer. IF your car is out if warranty.... contact your insurnace agent and see if headlights are covered. Just tell them you have a crack bc there is water inside of your headlight. MOST insurance policies cover rock damamge for glass under teh comp ins plan. Zero deduct too. Then have a dealer do the repair so you have a two year parts warranty on the headlight. |
03-30-2012, 04:33 PM | #18 | |
Rep 253
I'm hoping for the best because I damn sure don't want to shell out friggin' $1500 for a mere headlight.... |
03-30-2012, 05:45 PM | #19 |
European Editor
10624
Rep 22,992
I think your car will need not only a headlight but also a ballast and FWM as well. Plus coding for the new FWM. I bet that will make it more than a $2K repair! For just ONE side. GL.
03-31-2012, 12:41 AM | #20 |
Rep 253
That's fucking highway robbery. What kind of shit is that man? $2,000 for a freaking headlight?
03-31-2012, 07:30 AM | #21 | |
European Editor
10624
Rep 22,992
Originally Posted by Dackelone I think your car will need not only a headlight but also a ballast and FWM as well. Plus coding for the new FWM. I bet that will make it more than a $2K repair! For just ONE side. GL. Quote:
Just go to RealOEM.com and add up the parts needed... http://www.realoem.com/bmw/showparts.do?model=UC93&mospid=52062&btnr=63_1006& hg=63&fg=05 AHL Xenon = $863 Xenon bulb = $212 Ballast ecu = $450 FWM (not coded!) = 147 that is $1672 in parts only. Then pay your dealer at least $120 per hour to R&R the bumper and headlights and throw in a few hours for coding the FMW. Its easy to see how it gets so expensive. This is why I have said before its not worth it to me to mess around with some $30 brighter and different temp AE bulbs. |
03-31-2012, 12:23 PM | #22 |
Rep 253
There shouldn't be an issue with getting a used one off of eBay is there?
