04-18-2012, 04:41 PM | #1 |
432
Rep 4,650
♦ Sonic MS | PSi "RaceLine" Performance Coilover System (RACE-SPEC | 2-Way )
Greetings Gents,
Just wanted to share some pictures and information of this suspension kit for the E92 M3 that we installed for our client's AW E92 M3. PSi "RaceLine" Performance Coilover System (RACE-SPEC | 2-Way ) This kit consists of the following: - OHLINS 36-INV Dampers (Front) w/ External Reservoirs | TTX 36-IL Dampers (Rear) - Eibach ERS Springs ( 525F / 800R ) - Ground Control Spring Perches (Rear) - Ground Control Camber Plates (Front) Our client wanted the best suspension money could buy. As such - we opted for Performance Shock's new "RaceLine" suspension system for the BMW E92 M3. This kit features OHLINS 36mm "Inverted" front dampers w/ external reservoirs and TTX36 "Inline" rear dampers and this confiugration allows for a 2-way adjustable setup with 1-way compression and 1-way rebound adjustment. The inverted strut design, with large working cylinder diameter provides excellent lateral support while reducing friction. The rear Ohlins TTX36 inline rear dampers utilizes an integral reservoir that makes it very compact and keeps internal pressure of the damper unit to a minimum. The end result is a low amount of hysteresis - translating to excellent short stroke / high force performance. The Ohlins TTX range of shocks require very low gas pressure which considerably improves grip without any loss of damping performance. Feature Benefit Summary: - Extremely broad external adjustment range Front (20 clicks bump, 40 clicks rebound); Rear (22 clicks bump/rebound) - Low internal friction - Direct damping response / low N2 pressure - Inverted 36mm front struts - TTX36 Inline Rear Dampers - Easy to access external adjustments Included in the kit are the Rear Spring Perches and Front Camber/Caster Plates, manufactured by Ground Control. The externally mounted reservoirs (front) allows for easy access for dampening adjustment. In addition, custom rated helper springs (reverse mounted) are utilized to minimize stack height upon full compression in addition to pre-loading the primary Eibach ERS springs to prevent unnecessary movement and noise. Here you can see the external reservoirs mounted securely inside the engine bay for easy access. Next up - corner balancing and alignment. And then we take it to the track this weekend at MFEST!!! In case you missed the build - please reference the link below to the Sponsor's Project M3s section. http://www.m3post.com/forums/showthread.php?t=662270 Last edited by Cal@Sonic MS; 04-23-2012 at 01:56 PM.. |
04-21-2012, 12:10 PM | #3 |
Rep 197
Awesome... This setup looks pretty sick...
All Thanks 2: Velos Designwerks-Wheels Boutique-IND Distribution-McKennaBMW
Mod List: | ESS VT2-625 | Velos Designwerks Tune | HRE P40S | Brembo 380mm BBK | Akrapovic Evolution Exhaust | KW V3 Coilovers | Vorsteiner GTS3 Front Bumper | Vorsteiner Rear Diffuser 2 | BMW Blue PSW | BMW Performance Spoiler | BMW GTS Door Sills | BMW Performance High Gloss Black Grills & Gills | TiKORE Industries Titanium Lug Bolts | STRI Gauges | |
04-23-2012, 07:47 PM | #4 |
Rep 17,493
Drives: like I'M BOUT THAT LIFE
dayum! thas the real deal right thurr.
#datbimmerdoe #thatbimmertho
FOLLOW @datbimmerdoe on INSTAGRAM |
04-23-2012, 09:32 PM | #6 |
Rep 3,157
nice
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
04-24-2012, 08:11 PM | #8 |
Rep 3,157
the ohlins TTX46 is crazy it really just blows me away how stable the car is over the KW comp. set up its really hard to explaiin
04-24-2012, 08:23 PM | #9 |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
wow looks good, what is the pricing on this?
04-25-2012, 12:17 AM | #10 |
Rep 4,092
Drives: 21 X6MC
04-25-2012, 04:12 AM | #11 |
Rep 5,804
04-25-2012, 12:12 PM | #13 |
Rep 5,804
04-30-2012, 03:39 PM | #15 | |
BimmerPost Supporting Vendor
732
Rep 3,735
The heavy springs will eventually tear the shock tower.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
05-05-2012, 01:28 PM | #16 | |
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
I wonder if the same would ever apply to the E9X M3...
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
05-05-2012, 01:38 PM | #17 | |
732
Rep 3,735
Sadly, I have seen a few of these failures in the past year and it is not a fun repair.
07-24-2012, 06:54 AM | #18 |
Rep 1,665
08-07-2012, 03:09 AM | #20 |
Rep 1,665
08-07-2012, 07:50 PM | #22 |
Rep 3,479
Drives: 19 M2C 6MT
Those are gorgeous...
I wonder what the price is for it |
