04-21-2012, 08:12 AM | #1 |
Rep 153
annoying error message
Anyone get the following error msg on I Drive screen : transmission Position P not engaged". At the same time in the small driver screen an image appears of a car with left/right pointing arrows.
It happens a lot when you are backing the car out and most of the time when you select a forward gear. Its so stupid, of course Position P is not selected, I select Reverse to back out and D to go forward. Car is not disabled in any way but think its a sensor somewhere that could eventaully cause problems. Anyone have experienced this and what was the fix?? Thanks. chuck 2009 M3 44,000 miles |
04-21-2012, 08:26 AM | #2 |
Digger
209
Rep 2,619
This usually only happens when you get out of the car and don't shut it off. Never had it happen when I was actually still in the car....
2009 E92 M3 /// Melbourne Red /// Fox Red /// M DKG
Full Innotech Exhaust - DINAN Intake - IND Engine Bay Appearance - IND Hand Stitched Boot Covers - and much more.... |
04-21-2012, 08:35 AM | #3 |
Rep 1,253
Drives: F10535, E90M3, E30M3, E28M5
Garage List 2017 Alpina B6 GC [0.00]
2014 535xi M Sport [0.00] 2014 X3 3.5 M Sport [0.00] 2011 M3 E90 [9.74] 2007 Z4 M Coupe [7.00] 1990 M3 [9.50] 1988 M5 [10.00] |
^ same experience as Zach
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes |
04-21-2012, 08:36 AM | #4 | |
Rep 4,261
04-21-2012, 08:44 AM | #5 |
Rep 1,112
Same here, comes on once I put in neutral and unhook seatbelt to get out and want to leave running for a minute, etc to do something. just a safety warning.
...just enjoying life.
04-21-2012, 08:50 AM | #6 | ||
Member
75
Rep 379
04-21-2012, 08:52 AM | #7 |
Rep 1,895
04-21-2012, 08:59 AM | #8 | |
Rep 20,742
Drives: 2021 911 turbo
It is a warning to let you know the car is in neutral and can roll if the brakes are not applied. With DCT it is not possible to have a "park" feature with the engine running like there is on a standard autobox. For me, I only get the warning if the engine is running and I open the door. |
04-21-2012, 09:00 AM | #9 |
Rep 20,742
04-21-2012, 09:40 AM | #10 |
Rep 261
Comes on when the car is in neutral with the engine running. It's warning you that the car can roll away. Just like any manual transmission in neutral, there is nothing holding the car in place. If you are going to get out or want to park with your foot off the brake, you need to set the hand-brake or it will roll - that's what it's telling you.
The car does not have "park" like an automatic that can be engaged while the engine is running. The car puts itself in a park "mode" after the engine is turned off. I still set the hand-brake before exiting the car like I would any manual. Especially on a hill. That's just me. I'm used to driving manuals and since that's what a DCT is (a MANUAL transmission without a clutch pedal) I drive it like one. Think of it as a manual with an optional automatic shifting mode, rather than an automatic where you can just over-ride the shift points.
2011 E90, Melbourne Red, Bamboo, DCT, Premium, Comfort, Cold, Enhanced Stereo, Apps "I don't drive fast, I just fly low." |
