04-29-2012, 09:49 PM | #1 |
_______
170
Rep 1,088
KW V3 accessibility to the adjustments in the trunk
CHANGE 1 (went from a 2" hole and cover to a 2.5" hole and cover to allow more room to get a tool down into the hole to adjust the strut top rebound settings:
I had my trunk taken apart today and decided to figure out a way to reach the strut tops in order to make adjustments to rebound without having to take everything apart every time. Tools/Parts: Everything you need to take the lining out of your trunk Box cutter 2 x Furniture Hole Cover-2.5" (same thing you see in computer desks to keep the wires organized; found at Home Depot in the electronics aisle) Tape Measure Pen Step 1: On one side of the trunk interior, measure 3" inches down from the bottom of the plug just above where the strut top is. Mark that with the pen and then make a 2.5" circle around the center dot. Step 2: I originally bought a hole drill bit, but that didn't work. Use the box cutter to cut out the circle. Step 3: Insert the hole cover; repeat on the other side and reinstall the trunk interior. The only issue I had was that the 2mm Allen key isn't quite long enough. You can push down on the interior to get it more accessible. It's definitely more accessible than before though. I'm going to find a 2mm hex bit for my screwdriver; should solve the issue and make this really easy to adjust.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat Last edited by Longbow64; 05-05-2012 at 03:45 PM.. Reason: content |
05-05-2012, 05:45 PM | #4 |
_______
170
Rep 1,088
Updated. Made the hole bigger. (2.5" hole cover). You can do this mod without removing the trunk interior if you don't mind climbing in.
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
05-15-2012, 06:25 PM | #6 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Nicely done!
