04-30-2012, 05:20 PM | #1 |
445
Rep 1,658
New: APEX EC-7 Wheel
APEX is proud to introduce its new EC-7 wheel. This new wheel addresses the concerns of more and more racers and track day enthusiasts: long term durability, fit and performance. With the increase of faster and heavier cars being used in racing, HPDEs, and spirited driving, the EC-7 was designed and engineered to handle extreme abuse on track and street, offer a wide range of direct fitments, while producing a lightweight wheel. The new features offered make the EC-7 the perfect compliment to the APEX ARC-8. Race Silver Finish Profile 1 An optimized car setup begins with the perfect wheel fitment. Without the perfect offsets, maximum tire widths and the potential of your car are always compromised. With this in mind, the EC-7 has three unique face profiles ranging from shallow to deep concavity resulting in 13 unique 18″ sizes. This wide range of fitments allows for vehicle-specific caliper clearance, offsets, and tire widths, creating the most optimal setup possible. Available Sizes and Weights: 18x8.5" ET45 - 19.55lbs - 1 Series Fitment 18x8.5" ET35 - 20.10lbs 18x9.0" ET42 - 20.75lbs 18x9.0" ET31 - 21.25lbs 18x9.5" ET58 - 20.65lbs - 1 Series Fitment 18x9.5" ET43 - 21.55lbs 18x9.5" ET35 - 21.70lbs 18x9.5" ET22 - 21.75lbs 18x10" ET43 - 21.70lbs 18x10" ET33 - 22.50lbs 18x10" ET25 - 22.45lbs 18x10.5" ET27 - 22.50lbs 18x11" ET25 - 23.35lbs Available Finishes Race Silver Anthracite Satin Black The EC-7 adds 7 new BMW sizes not available in the ARC-8 design. The 3 face profiles offer maximum concavity and reduced weight. This avoids the common adaptation of a single face profile for unintended fitments or dependency on spacers. The EC-7′s spoke profile has been designed with a curve to provide additional caliper clearance. It can clear a BBK spacer free on applications where the ARC-8 could not. A significant improvement to the EC-7 is the increased barrel clearance that now allows for the 18″ version of this wheel to properly clear the Brembo 380mm BBK. Anthracite Finish Profile 1 Satin Black Finish profile 1 Just like the rest of the APEX wheel line, the EC-7 is once again produced using the Flow-Forming technique. Flow-forming, which has also been called “roll forging” or “spin forging”, produces a barrel with similar strength to that of a fully forged wheel. This significantly reduces weight in the barrel, which has the greatest impact on rotational mass. We’ve produced an even stronger wheel by combining the strength of the lightweight barrel with a more robust face design. The EC-7 welcomes endurance racing and potholes. Designed for BMW applications, the EC-7 accepts TPMS sensors, factory lug bolts or stud conversion kits, and OEM roundel center caps. All wheels come with APEX center caps. Test Fitments: Anthracite 18x8.5" ET45 front with 235/40/18 Anthracite 18x9.5" ET58 rear with 265/35/18 Car is on Koni yellows, stock sport springs, and M3 control arms.
04-30-2012, 05:24 PM | #2 |
Rep 4,155
Drives: 1/18 Monte Carlo Blue E92 M3
Soooo what's the biggest tire size we can fit on these without rubbing? 255 front with -3 camber and 275 rear?
04-30-2012, 05:43 PM | #4 | ||
445
Rep 1,658
We recommend 265/35 for the rear. Some 275 tires may fit, but the offset of this wheel is 4mm lower than the ARC-8 for the rear, which will make the fitment closer to the fender, resulting in possible rolling. Quote:
04-30-2012, 08:25 PM | #6 |
445
Rep 1,658
No. That is profile 3.
04-30-2012, 09:11 PM | #9 |
Rep 530
These are so nice. I too would be interested in a group buy.
KW V3's, Sparco Pro2000's, Vorshlag CP's, JB4, Heat Wrapped Raceland DP's, aFe stg. 2 Sealed Intake, Miro 111's, Hankook RS3's 225/245 (for now), Seibon M3 CF Hood, Turner Motorsports Alum. Radiator, Big Tom IC, BMW Performance bumper.
04-30-2012, 09:30 PM | #10 |
Rep 128
Will you keep the price the same as the 8's
Edit**** oops I just saw this will be a technical thread about fitment. July is to long of a wait. I need these now. I'll be more than happy to test a set for you |
04-30-2012, 10:46 PM | #11 |
Bimmer Newbie
22
Rep 312
Drives: CSM N54 Prem/Comf/Sound
I just wanted to congratulate a vendor who's stepping out and making nice / light rims that actually fit our cars... thx!
I'd also be interested in a GB...any chance of getting these in a polished finish? Nice and shiny for a Cashmere Silver 135i... Also, why a different offset than the arc-8? I was looking forward to some 275s on the rear! |
05-01-2012, 09:42 AM | #13 |
Rep 667
Drives: 2012 128 Coupe
can you provide tires as well so that if purchased from you they arrive completely assembled and ready to mount?
Current Daily Driver: 2015 X4 35i
Retired: 2012 128i Coupe M-Sport Retired: 2009 X6 35i Retired: 2003 X5 4.6is Retired: 2006 330i Post September |
05-01-2012, 07:26 PM | #16 |
Rep 1,585
Drives: 2011 VO 1M
Garage List 2010 Porsche 911 GT3 [10.00]
2021 BMW X5 SD40i [0.00] 2023 Toyota TRD Pro [0.00] 2011 BMW 1M [9.83] 2014 Ford Raptor [0.00] 2005 Ariel Atom 2 [0.00] 2008 135i SOLD [10.00] |
Been anticipating these, I'm in if pricing is around the ACR 8s, going to use these as DD wheels and keep the ARCs for the track. Up for GB!!
///1M #643 of #740
05-01-2012, 11:44 PM | #17 |
Rep 846
Drives: 2014 F10 M5
GROUP BUY!!
05-02-2012, 10:19 AM | #18 |
Rep 222
Yes! This is Exactly what i need! Assuming the pricing is inline w the arc-8s of course... The only thing i dont like about the arc-8s is that flatness or lack of concavity for the 1 fitment sizes. So down for the group buy!
YMB M4, work in progress...
05-03-2012, 06:58 PM | #21 | ||||
445
Rep 1,658
The offset were improved based on customer demand. Only 1 in 20 customers or less would install 275 tires on the 9.5" wheels. The rest used 265/35/18's and the 4mm more aggressive offset is better for that. The new offset does not completely prevent the installation of 275 tires though. We'll do some testing when we can and verify that 275's will still fit (possibly with a very minor fender roll). Quote:
05-03-2012, 09:27 PM | #22 | |
Cone Cruncher
31
Rep 534
Tags |
18x8.5, 18x9.5, apex, ec-7, wheels |
