BMW M3 Forum (E90 E92)
BPM
      04-30-2012, 10:16 PM   #1
py0413
py0413's Avatar
Drives: Slow
Flat tire fix, then ABS warning signal CC-ID24. What's that about?
I took a 700km drive over the last 2 days and unfortunately had a small nail in my passenger side rear tire. Lucky enough the Tire Pressure Warning signal came up while I was passing by a small town in the middle of nowhere and found tire shop to fix that. Shortly after, (10 mins) the orange ABS warning came up and went off. I stopped and checked the tire pressure on all four tires, nothing was wrong, no more leak. So, I started the car again, the ABS signal came on again, then set it off in about 10 mins. I had to stop several times just to make sure no more leaking on my tires. I have 6 speed, no I-drive, the only thing I can get to know is the error code "CC-ID 24". My last nearly 250km going home was full of uncertain and when I finally got back home and phoned the dealer, they said they had no idea what that code was about and wanted me to bring the car in for a check up.
Anybody experienced similar problem? I had a flat tire before and nothing triggered the ABS warning like this time. Luckily, I am still under warranty protection. Will report back as soon as I hear from dealer.
Must stop eating..............
m3post
