05-04-2012, 09:34 PM | #1 |
Rep 4,092
Drives: 21 X6MC
KW V3 Dampening Question
So after installing my KW V3, when I push the push the car on full throttle I feel like my steering wheel is floating due to the tq and power in the rear. If I stiffen up my damper on the rear, will this help make the steering wheel feel more planted? This float feeling is not good. It feels like it's hydroplaning on water.
05-04-2012, 10:57 PM | #2 |
You got my money?
3198
Rep 4,676
Drives: Ice Cream Truck
Yes.
What settings are you using? Are you using KWs recommended setting? If not, I would start there first. KWs recommended setting is usually on the stiffer side of things. Its a PITA no doubt though. Changing them over and over until you find the spot you like. And not being able to get to the compression and rebound easily sucks too. Good luck man!
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
05-04-2012, 11:08 PM | #3 | |
Rep 4,092
Drives: 21 X6MC
05-06-2012, 03:37 AM | #4 |
Moderating
418
Rep 2,047
Firstly make sure you have the ride height set correctly
If the fronts are much higher than the rears you will have more weight distributed rear Corner weights are best to get this right but rule of thumb is 1 finger clearance front tires to fender and slightly lower clearance on the rears as the fender sites higher This gives best feel of balance I just fitted KWV3 on my new E90 and settings are Front C three clicks out from full hard R 6 clicks out from full Rears C 6 clicks out from full tight/in R 7 clicks out |
05-06-2012, 01:57 PM | #5 | |
Rep 4,092
Drives: 21 X6MC
05-06-2012, 02:03 PM | #6 | |
Rep 4,092
Drives: 21 X6MC
05-06-2012, 03:44 PM | #7 | |
Rep 4,092
Drives: 21 X6MC
05-07-2012, 01:21 AM | #8 | |
Moderating
418
Rep 2,047
Your floating sensation was probably because the rebound was set too soft The KW instruction manual (which I found yesterday) says Front Reb 6 clicks out Comp one full turn out (around 6 clicks) Rear Reb 9 clicks out Comp one full turn out (6 clicks) I prefer it a little harder hence my settings I actually set the fronts to C 4 clicks out and feels a little better, not so jarring on fast bumps/imperfections in the road |
05-07-2012, 10:18 AM | #9 | |
Rep 4,092
Drives: 21 X6MC
05-07-2012, 12:31 PM | #10 |
Moderating
418
Rep 2,047
I just set mine at
Front C5 R5 Rear C6 R7 This is close to factory suggestion only slightly harder on fronts (1 each) and on rears 2 harder on R Found mine a little tight on rear and lost a bit of traction. Hold on... That's the SC lol . No seriously I think these settings are the right set up |
05-07-2012, 12:36 PM | #11 | |
Rep 4,092
Drives: 21 X6MC
I'll give it a try! |
05-07-2012, 12:38 PM | #12 |
Moderating
418
Rep 2,047
What is (C) and (R) that you are stating? I hope my ride height is even. I feel like my front should be dropped more or something.[/QUOTE]
Remember ride height is easiest to work out by using one finger gap front tyre to fender and 1/2 finger rear tire/fender gap. You should be pretty well balanced on that My previous E92 was corner weighted and if you look at my pious threads of COTM aug or sept 2010 you can see the ride heights We should call this the Bob and Bapesta thread lol |
05-07-2012, 02:15 PM | #13 |
Rep 4,092
Drives: 21 X6MC
Team FI! |
05-16-2012, 11:33 AM | #14 |
Rep 565
I'm about to start playing around with this. I feel like it's a bit squishy on hard launches and it also has a rocking sensation when going over sequential bumps.
Designer & Photographer
05-16-2012, 11:52 AM | #15 |
Rep 4,092
Drives: 21 X6MC
05-16-2012, 01:02 PM | #16 |
Rep 565
Cool. I'll try it this weekend. I also want to raise the rear a little to see if it eliminates the rubbing. I want to keep the 295's. Also, what kind of tire pressure are you running?
05-16-2012, 01:11 PM | #17 |
Rep 4,092
Drives: 21 X6MC
Yeah, raise the car first. I rolled my fenders and ended up paying close to 1000 to get everything fixed because of the crack paint. I believe my pressure is at 44?
06-06-2012, 03:27 PM | #18 |
Rep 565
Alright, finally got around to some trial & error runs. Took the trunk liner out for a couple of hours yesterday (which is a b*tch to put back in) and made some minute adjustments.
Settled on this for now and it feels pretty comfortable without sacrificing responsiveness. I do, however, still have this vibrating sound coming up through the dash when I go over brick roads and some sharp bumps. It annoys the sh*t out of me. Any thoughts on that? Bump
Rebound
03-31-2013, 12:19 PM | #19 |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
I know this a very old thread, but curious what is the max amount of "clicks" on the kw v3s?
-nevermid found in the manual Last edited by mkPOTO; 03-31-2013 at 12:34 PM.. |
07-25-2014, 02:22 PM | #20 |
Güdentyte
1171
Rep 1,207
bump for an old thread.
what's the ideal track settings for the KW V3 ?
CURRENT - 991 GT3 | Future Classic 1M | Model 3 | T4R TRD Pro Lime Rush
SOLD - MB M2 CS | SMB F80 M3 CS | E90 M3 | E90 335i | E46 M3 Vert | E39 M5 | E34 525i |
07-25-2014, 02:38 PM | #21 | |
O! So Sour!!
552
Rep 15,615
Drives: Fast 240z / Slow M3
also what settings should i adjust to decrease understeer??
07-26-2014, 04:57 AM | #22 |
Rep 1,388
subscribed
