05-22-2012, 11:50 AM | #1 |
Rep 72
2012 E93 Coming Soon
So my E93 is currently being built and I'm thinking about mods already
My vert is fully loaded with EDC, DCT, 19's I hope to improve on the handling characteristics and get some additional power while staying naturally aspirated. I have no plans to track, but might want to autocross. Some ideas I have: Dinan Stage 3 suspension (to lower center of gravity & get less roll on curves) Dinan carbon fiber front strut tower brace (to stiffen up vert) 12 mm wheel spacers (better cornering) Brembo GT 380 mm brakes Minor performance tweaks - Dinan ECU Flash Dinan underdrive pulley High flow intake Cat-back exhaust - not sure which Got any suggestions for me? |
05-22-2012, 11:58 AM | #3 |
Rep 72
05-22-2012, 12:04 PM | #4 |
Rep 4,488
If you're not going to track (and especially if you just think you "might" autocross), a BBK is a total waste of cash unless you just like the look -- and StopTech and AP Racing both make BBKs that cost less than the Brembos and work just as well. See how your stock brakes hold up first; they're PLENTY for the street and probably even for autocross. If you do somehow experience brake issues, a soft pedal will likely be first, which is easily and cheaply cured with better brake fluid. If you then experience pad fade, that can be fixed just with better pads (StopTech Street Performance is a good combo street/track pad, and there are of course better pads dedicated to track use). A full-on BBK is only for skilled and frequent track junkies and typically only necessary to withstand the levels of brake heat generated by running competition tires or slicks. If you're thinking that a BBK will somehow reduce your stopping distance, think again. They don't reduce stopping distance AT ALL except when compared to an OVERHEATED stock brake system. Stick to better fluid and possibly pads unless you outgrow those much cheaper, more practical, and more easily reversible mods.
As for the rest, honestly I don't think you'll notice a handling improvement from any of that on the street, maybe not even in autocross since the speeds are lower. I'd strongly recommend getting a feel for what your car can do from the factory before you think about ways to "improve" it. Odds are its stock limits will already be way higher than your driving skills, in which case your money would be far better (and more enjoyably) spent on HPDEs to improve said skills. I've done 4 track days in this car bone stock, next month will be the first time with upgraded fluid (plan to upgrade pads later), and I feel absolutely zero need to change anything in the suspension, never mind the engine, because I can't drive my car anywhere near as fast as it can go the way it left the factory. Hell, my instructor is faster than I am while he's driving his E36 M3! Which leads me to my question: Why DON'T you have plans to visit the track? A well-run HPDE with good instructions is the best possible way to experience your car, highly educational, and one of the most fun per dollar experiences you'll find. Seriously OP, stop reading about all the ways to give your car "more" this or "better" that in your (completely understandable) anticipation of your new baby -- you don't even know what the baseline is yet! I think you'll find that she's plenty capable the way she is, and if she's not, the primary bottleneck is probably you not knowing how to drive her better -- in which case she'll thank you for taking her to the track and you'll both have a lot of fun. Remember, the most significant speed modification that can be made on ANY car is the driver. After that, it goes tires, brakes, and THEN suspension and engine.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 05-22-2012 at 01:58 PM.. |
05-22-2012, 12:46 PM | #5 | |
Rep 72
05-22-2012, 12:48 PM | #6 |
Rep 1,343
Drives: BMW M3 DCT
congrats
05-22-2012, 12:55 PM | #7 | |
Rep 4,318
The stage 3 kit will help with handling but doesn't lower the car much compared to other springs/kits Strut tower brace won't do much (if anything) more than the stock brace Spacers won't get you better cornering (at least anything you will notice) - they are really for appearance or adjusting wheel offsets for things like clearance Brembos are a waste if you won't track it (and I wouldn't do it in a vert anyway) - buy them if you like the look You have a lot of mods listed, some with the wrong reason. I would suggest getting know the car a bit then add the mods like exhaust, springs, etc. And while I like Dinan products, in many cases there are better/cheaper alternatives.
GT3 RS | Desperately seeking the next great M car...
05-22-2012, 01:05 PM | #8 |
Rep 15,818
05-22-2012, 01:16 PM | #9 | |
Rep 4,488
Yes, the added weight and consequent softer suspension will ding you a bit compared to the E92/E90, but the cost of all the mods you listed would buy a LOT of track weekends, which would put far more grins on your face and help you go much faster in your car than mods. Swapping hardware is no substitute for driver improvement. And remember, it's not as if the E93 has the weight of a Dodge Challenger and the suspension softness of a Lexus. It's still biased heavily toward all-around performance, so weight and suspension won't become the real issue until you've been on track a few times. And on the street, other than losing some straight-line acceleration, I doubt you'd really notice much if at all. A stock E93 M3 can still corner at unsafe-for-public-roads speeds.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
05-22-2012, 06:43 PM | #10 |
Rep 4,318
Biting your tongue? Not ripping on verts being too slow or heavy at the track (my E46 M3 vert was my favorite car) but not safe in a track environment IMO. I wouldn't track it without at least a partial cage.
05-22-2012, 08:39 PM | #11 | |
Rep 15,818
(those are actually amazing track cars though)
05-22-2012, 09:27 PM | #12 | ||
Rep 1,052
Drives: 2022 X3MC; 2012 M3 Cabriolet
It has the automatic roll-bar safety system (you can YouTube for video examples of it) which makes the convertible qualify for most Texas-area Track-Days that I've searched. Last month I did all 90 miles with the top-down around MSR Houston -- it was amazing and fun. No, it won't be as fast as a typical E90, a low-budget Bugatti Veryon, or a five-year old Lamborghini -- WhoTFCares? Have fun! (and get a GoProHD2 before your Track Day!)
2022 ///X3M Competition; São Paulo Yellow
2012 ///M3 Cabriolet; Le Mans Blue Metallic. >177k miles and still rocks! |
05-23-2012, 09:30 AM | #14 | |
Rep 4,488
A GoPro can very fun, but honestly until you get the fundamentals down I don't think they're that helpful. Once I get a bit better I may look into the Harry's LapTimer iPhone app since it can take video as well map your laps on GPS (to compare your line lap to lap) as well as display speed, braking, and even RPM data from each point on the track if you get the proper accessories. But studying all of that your first few times out would be putting the cart before the horse IMHO. It's funny, I've wondered for a while what the all fuss was about with verts and finally got a chance to try one this past weekend. At our CCA chapter drive, I swapped my M3 with a friend who had a Z4 M Roadster. I realized the convertible experience wasn't for me. You can't have a conversation at 70 MPH, I got sunburned, it was a little TOO hot and at least that car's AC didn't help with the top down, and when I'm out to go DRIVING I can't spend a lot of time looking up and around me to enjoy the view, never mind behind me. I can see the view being great for passengers or maybe for me when driving slowly through downtown San Francisco or in a narrow canyon, but I don't buy my cars for my passengers' enjoyment. In the end I realized that for me, my E92 with the windows down and the moonroof open gives me plenty of wind from outside with better temperature control capability while still giving me almost the same view above and side to side (the only part blocked is the relatively small area between the top of the side windows and the edge of the moonroof). So for me a convertible would be paying a bunch of extra money for downsides, including the extra weight, softer suspension, roof mechanism liability, and the fact that the ONLY convertible I've seen whose looks I can stand with the top up is the current Z4. The E93 is close since it's a hardtop (hate ragtops) but the chopped-up roof, lack of shadowline trim, and strange way it touches down on the trunklid just don't do it for me personally. That said, I absolutely LOVED the Z4M drive. If the only current Z4 had an M coupe variant rocking an S65... (And no, the GT3 doesn't count!)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 05-23-2012 at 09:52 AM.. |
